Old 07-06-2005, 04:43 PM   #15481
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
I sorry I stand corrected.
Here's the part number for a manual you can order T0021
ROBBIE C is offline   Reply With Quote
Old 07-06-2005, 09:55 PM   #15482
Ok so the front belt on my MTX3 is done for, my question is, i have talked to some people that say that u can cut off every other tooth on the belts to cut down on resistance. But how much does this help and how to the mugen belts hold up to this.
ATXPro4 is offline   Reply With Quote
Old 07-06-2005, 10:11 PM   #15483
mkristanto's Avatar
Default clutch spring
i changed my gearing to 0.8 module recently and follows the mtx 3 prospec ration. But i found my low end really bad.
I tried to thighten the clutch but does not really help.
My question is should i use the silver clutch spring (option part) since currently i am using bronze color clutch spring (original from mtx3)???
Can someone help?? Thanks a lot...
mkristanto is offline   Reply With Quote
Old 07-06-2005, 11:44 PM   #15484
Does anybody know where I can get an aluminum front bulkhead for the mtx3?
shadow1208 is offline   Reply With Quote
Old 07-07-2005, 04:17 AM   #15485
Winner's Circle's Avatar
Default cutting teeth off of the belt
This is not a good idea. The belt life will be very short. Kawahara make low friction belts for the MTX3 that reduce friction without shortening the life of the belt. I have these in stock.
Lee Muse
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 07-07-2005, 04:19 AM   #15486
Default gear ratio issue
The problem is the gear ratio. The lowest 0.8 gear ratio is higher than the lowest ratio available with the standard gears. This will reduce your punch out of the turn assuming you were previously running the lowest ratio.
Lee Muse
[email protected]
Old 07-07-2005, 06:35 PM   #15487
mkristanto's Avatar
Hmmmm ok thanks for the advice....however that ratio is the standard ratio use for prospec....
Well let me experiment again . Thank man
Old 07-07-2005, 06:39 PM   #15488
Default Check it out
www.rcauctionhouse.com
inthedust is offline   Reply With Quote
Old 07-07-2005, 06:43 PM   #15489
Old 07-07-2005, 07:12 PM   #15490
gonzoY5's Avatar
Check your clutch setup. it makes a huge difference. The .8 Prospec gear setup will give plenty of bottom end. Make sure you have enough spacers before the first clutch bearing so the bell spins free without rubbing the clutch shoe. I usually just add until it wont rub anymore then add 1 more shim. Then set the endplay. If you've got the lightweight shoes and the super hard spring, start with the clutch nut about 9mm from the end of the crankshaft. That's a usually a good start for me then adjust the spring again accordingly till you get the accelleration that you want.
gonzoY5 is offline   Reply With Quote
Old 07-07-2005, 08:12 PM   #15491
mkristanto's Avatar
Yes i did the clutch setup already and it works just fine with 1.0 module. The clucth nut setting is already 10 mm if remember correctly.
I think i need to change to super hard spring since i'm using the standard spring.
Wat setting and ratio you run currently?
Old 07-09-2005, 07:37 PM   #15492
P-DUB's Avatar
Hey Robbie....Did you ever get a bumper from Darin or Mike? If not, let me know and I will get one on the way
Paul Wynn
Larry Pryor
P-DUB is offline   Reply With Quote
Old 07-10-2005, 08:31 AM   #15493
SpeedChair's Avatar
Trader Rating: 15 (100%+)
Default Starter Box
I have a starter box setup for a Mugen MRX-3...does anyone know if I can use the same setup without moving the plugs for the MTX3. That would be awesome if I can...Thanks ahead.
SpeedChair is offline   Reply With Quote
Old 07-10-2005, 01:24 PM   #15494
Fsturbo15's Avatar
Send a message via AIM to Fsturbo15
Default 16/19
I want to go 16/19 but I dont have a tire truer, do you guys still think its worth doing if I cant true my tires,
I hear you have to true the fronts if you use 16/19.
Think i'm better off with the stock pulleys?
Fsturbo15 is offline   Reply With Quote
Old 07-10-2005, 04:30 PM   #15495
chris-steele's Avatar
Send a message via MSN to chris-steele
Go to this sitehttp://home.tiscali.be/be067749/58/ and it should answer many of your questions. Look at the Touring Car Setup Guide
hi your URL does not work.
chris-steele is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
