Old 06-11-2005, 01:30 AM   #15301
asw7576's Avatar
Is this statement true :
harder damping ( thicker oil shock ) = slower corner entry speed & slower mid cornering speed.
Old 06-11-2005, 07:34 AM   #15302
rcabj's Avatar
Talking
only thing i understand about shock oil is if the track is level use thicker oil...and thinner oil for bumpy surfaces....on the other hand if we want more grip use light oil and vice versa...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 06-11-2005, 12:29 PM   #15303
performula's Avatar
I have had to play with the linkages for nearly two hours now. Is there an aluminum servo horn that will directly bolt onto Futaba servos WITHOUT the need for an adaptor?
performula is offline   Reply With Quote
Old 06-11-2005, 12:44 PM   #15304
gonzoY5's Avatar
http://home.tiscali.be/be067749/58/
Check that site out. It has all kinds of "rules" of what to do and when. Should answer your questions. There's a lot of detailon the entire site, but check out the Touring Car Setup Guide for quick answers
gonzoY5 is offline   Reply With Quote
Old 06-11-2005, 09:49 PM   #15305
performula's Avatar
I cannot get the gears off of the clutchbell; are there any other ways to get these off besides the Mugen pinion gear removal?
Old 06-12-2005, 01:30 PM   #15306
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
two pair of channel locks
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-12-2005, 02:03 PM   #15307
performula's Avatar
How do you keep from ruining the gears and bending the clutchbell?
Old 06-12-2005, 05:49 PM   #15308
20 SMOKE's Avatar
you don't grip it that tight and put a rag on it so you don't mark it up
Jamie W
Old 06-12-2005, 06:02 PM   #15309
gonzoY5's Avatar
I tried all the tricks with channel locks and vice grips and all that, because I was trying not to buy the tool. But once I tried the Pinion tool it was so damn easy, it's absolutely worth it. I know it's not cheap, but you're going to need it. Break down and order it
Old 06-12-2005, 08:06 PM   #15310
performula's Avatar
Where can I get one?
Old 06-12-2005, 08:22 PM   #15311
rocca30's Avatar
just buy the tools. its well worth it.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 06-12-2005, 09:34 PM   #15312
I just finshed building my MTX 3 and all is left is some final adjustments , but i have a couple questions
ON the setup sheet it lists rebound stop adjustment , is this the smae as droop ? also in the rear it suggests only 6mm , which leaves almost no down travel , would i add more droop if the track is bumpy or need more trraction on that end of the car ?
There is also a listing for bump stop, and it lists no , is this the uptravel limiting adjustment ? under what conditions would this adjustment be used ?
ON adjusting rear toe in it suggests 2.5 deg ,is that per side or total rear toe in ?
SO far im impressed with the car , looks extremely strong compared to the NTC3 that I ran last year . Hopefully next weekend i will race it .
Eddie is offline   Reply With Quote
Old 06-12-2005, 09:59 PM   #15313
gonzoY5's Avatar
Yes, Rebound Stop = Droop.
6mm is works fine, but with smaller tires you may need to use more droop.
I've never used bump stop, so maybe someone else could clarify.
The toe-in is 2.5 on each side.
This site http://home.tiscali.be/be067749/58/ should answer many setup questions you may have. (Except bump stop )
Old 06-13-2005, 01:23 AM   #15314
geo_mtx3's Avatar
Cool negative dif
Has anyone tried the negative dif
geo_mtx3 is offline   Reply With Quote
Old 06-13-2005, 01:35 AM   #15315
asw7576's Avatar
Nice article to read. Thanks GonzoY5.
Performula: make sure the engine's bottom screws ( 4 of them ) are securely tight to chassis and they will not move after impacts. That's maybe the reason of ruined spur gears.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
