Old 05-08-2005, 07:38 PM   #15061
performula's Avatar
With the so called release of the MTX4, will Mugen still manufacture parts for the MTX3?
For instance, anyone still use their MTX2?
performula is offline   Reply With Quote
Old 05-08-2005, 08:15 PM   #15062
superk's Avatar
What "MTX4"?? any new info? Link? Pic? Love my MTX3 dont want na switch yet. lol
superk is offline   Reply With Quote
Old 05-08-2005, 10:49 PM   #15063
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Hey guys,
Can you tell me the difference in the A, B, and C blocks in the rear of the car? Will the C block give more traction versus the B and A blocks?
EA Motorsports
picco007 is offline   Reply With Quote
Old 05-08-2005, 11:07 PM   #15064
gonzoY5's Avatar
Default Re: Loose on Power only when turning right
Originally posted by TAW
My MTX-3 has developed a loose condition on power but only when turning to the right. this seems to have happened afer a nasty crash a few weeks ago. I have gone though and checked all the obvious causes. I did find that the radio plate was cracked and the aluminium radio tray support was bent. I replaced those with new ones. I have the 4mm chassis and it does not seem bent. I did not take it off the car but on a flat surface while attached to the care it seems straight. Put it on the tweak station and it seems fine. This is only when turning right, basically if I give it gas it spins out. To the left I can hammer the throttle all day and it never breaks loose. I am a little stumped. any suggestions?
OH MY GOD I HAVE THE EXACT SAME PROBLEM. Happens to me more on sweeping turns toward the middle and exit. I've done all I could imagine and get get it fixed. Let me know if you figure it out.
gonzoY5 is offline   Reply With Quote
Old 05-08-2005, 11:32 PM   #15065
superk's Avatar
I have some similar problem. What I found was in my carbon fiber front shock tower. Some how...I broke it. It just crack enough to bend the shock tower it self...and enough for you to just miss it. Some how stock shock tower was easily brocken. I did upgrade to 3racing thick tower.
Old 05-09-2005, 07:10 AM   #15066
picco007's Avatar
Another question, what diff lube are people using in the rear? Thanks
EA Motorsports
Old 05-09-2005, 06:57 PM   #15067
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Well, after tearing down the car it looks like my 4mm chassis it slightly bent in the front. On a flat surface the front area where the bumber mounts is about 1~2mm off the surface. Weird part is it almost looks exactly even side to side so its odd that it only affected right hand turns. I guess a tweaked car will do wierd stuff?
TAW is offline   Reply With Quote
Old 05-09-2005, 08:08 PM   #15068
MAVICXXX's Avatar
bro,that depends on d track surface and your driving style..me just gota try my new mtx wit jus defaulft factory set up on med range speed,medium tide,medium surface.
low traction track should go wit lower dif oil,hi trac should put in higher,anyway u can stil compromise wit tyres and suspension..
MAVICXXX is offline   Reply With Quote
Old 05-09-2005, 08:37 PM   #15069
performula's Avatar
Default Re: Re: Loose on Power only when turning right
I noticed this with my R40 this afternoon while taking my car apart, perfectly even, but the front was a tad higher.
I think that there is a lot of twist going on from the belts and pulleys, add a 1.4-1.7HP motor to the equation and it might make since. That could have caused the problem.
Old 05-09-2005, 09:53 PM   #15070
picco007's Avatar
Yeah,
I went from 10k to 30k and it made a big difference. Many people are using 50k in their diffs. I just don't understand why they have good results with that. Oh well I'm going back to 10k.
EA Motorsports
Old 05-10-2005, 02:16 AM   #15071
teammpp's Avatar
Yeah,
We run 100k on one of our tracks. Depends on how much grip is available and whether the track is real smooth or very bumpy etc...
teammpp is offline   Reply With Quote
Old 05-10-2005, 04:30 AM   #15072
asw7576's Avatar
Must be awesome pull on exit.
Old 05-10-2005, 09:08 PM   #15073
MAVICXXX's Avatar
wow..! almost goin to solid axle..
well its true,all up to track surface,low traction use lower dif oil,hi traction higher oil,but solid rear actualy difnrt car reaction..
Old 05-11-2005, 12:57 AM   #15074
asw7576's Avatar
I take out the front and rear stabilizer, it's driving like electric car now.
Old 05-11-2005, 07:48 AM   #15075
performula's Avatar
So removing the stabilizers makes the car easier or harder to drive?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
