Old 04-25-2005, 01:51 PM   #15001
gonzoY5's Avatar
Check that all the pulley set screws are on the flat spots of the shaft. I had that happen a few times. You pick that car up and give the wheels a spin and it all looks good, but under load from the engine it just spins free. Loosen them all and tighten them up again w/a little blue locktite.
gonzoY5 is offline   Reply With Quote
Old 04-25-2005, 02:14 PM   #15002
Toma2525's Avatar
thanks for all the suggestions. looks like i have some work to do!
Toma2525 is offline   Reply With Quote
Old 04-25-2005, 05:16 PM   #15003
mckrooz's Avatar
Send a message via AIM to mckrooz
Also check the dogbones or universals. If you are missing one, that could cause it to veer.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 04-26-2005, 02:04 AM   #15004
MAVICXXX's Avatar
Originally posted by Palmaris Europe
1700g minimum weight.
Most Prospec Mugens are weighing in close to 1800g stock depending on the radio gear used.
wow!i v got to loose bout 80grams for the asian mugen final!!ride on mtx3 kit better i guess..
MAVICXXX is offline   Reply With Quote
Old 04-26-2005, 03:02 AM   #15005
asw7576's Avatar
Originally posted by Toma2525
Trouble! I can't figure out what could be wrong. Under initial acceleration, my MTX3 bolts to the right. It is undrivable. I checked the belts thinking that could be it. All good. Then I noticed that my rear differential was "oily", like it had leaked. Could this be it? I am planning a rebuild of the rear dif. Any input would be appreciated. Thanks.
Because this problem is major and you need to rebuild the diff anyway, I think it's time to rebuild everything and inspect all parts.
Old 04-26-2005, 06:00 AM   #15006
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally posted by AMGRacer
Minimum IFMAR weight is 1725 including transponder no fuel. Rule 5.9.
ok guys thanks for the clarification
buboy28 is offline   Reply With Quote
Old 04-26-2005, 04:11 PM   #15007
what is the maximum weight of the car according to IFMAR including full tank, full set of tires and transpounder?
thanks
Alex
brooklynrc is offline   Reply With Quote
Old 04-26-2005, 04:15 PM   #15008
Derby Bros Racing's Avatar
hmmm.. i'm curious to know the maximum weight also. i always thought the only concern is the minimum weight.
Derby Bros Racing is offline   Reply With Quote
Old 04-26-2005, 08:06 PM   #15009
MAVICXXX's Avatar
1725grams(after race condition) wit tranponder witout fuel.
thats why i said i v got to loose bout 80grams
Old 04-27-2005, 04:54 AM   #15010
straightsixers's Avatar
I don't think there such a thing as maximum weight.
If anything - everyone else would be happy that you're over weight!
straightsixers is offline   Reply With Quote
Old 04-27-2005, 09:15 AM   #15011
that is good to know becauase i thought that they were measuring max weight also. but you are right, it makes sense, max weight should not be an issue
Alex
Old 04-27-2005, 11:20 AM   #15012
that's what i thought
Old 04-27-2005, 11:50 AM   #15013
teammpp's Avatar
no max weight rule. just min weight at 1725g.
To ensure you dont go below this weight it is best to weigh the car with rims but no foam or very very worn full wheels.
teammpp is offline   Reply With Quote
Old 04-29-2005, 06:29 PM   #15014
gentleman81's Avatar
Default tire diameter
what is the result of running smaller diameter tires up front?
and vice versa?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-29-2005, 07:27 PM   #15015
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The car won't handle quite right with larger fronts. Besides that, most people find the rears wear faster, so you normally start with smaller fronts.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
