Old 04-24-2005, 08:38 PM   #14986
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally posted by mavicRR
tq..are u running prospek or just mtx3 kit?i am thinkin of just race wit d mtx3,what do you think?well ofcoz d prospek ofers more options,but its a bit heavy..IDEAS?
I am running the PROSPEC kit, the MTX-3 is a great kit.
What do consider heavy?
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 04-24-2005, 09:37 PM   #14987
Vinyard's Avatar
I had a fren who went Ti for everything available on the MTX and its way under-weight for IFMAR ruling..
I would think the Propecs MTX is just abt right on the weight.
Vinyard is offline   Reply With Quote
Old 04-25-2005, 12:35 AM   #14988
asw7576's Avatar
What minimum weight rule according IFMAR ?
Old 04-25-2005, 02:02 AM   #14989
teammpp's Avatar
1700g minimum weight.
Most Prospec Mugens are weighing in close to 1800g stock depending on the radio gear used.
teammpp is offline   Reply With Quote
Old 04-25-2005, 03:08 AM   #14990
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
does the minimum weight means fuel and transponder included
buboy28 is offline   Reply With Quote
Old 04-25-2005, 03:47 AM   #14991
teammpp's Avatar
minimum weight is measured with transponder but no fuel.
Old 04-25-2005, 05:47 AM   #14992
Trader Rating: 15 (100%+)
What changes when you change to the A,B or C rear blocks. I am running in a spec class that we have to run rubber tires. Just wondering what would give me the most rear traction?
THE DOCTOR is offline   Reply With Quote
Old 04-25-2005, 05:57 AM   #14993
AMGRacer's Avatar
Minimum IFMAR weight is 1725 including transponder no fuel. Rule 5.9.
AMGRacer is offline   Reply With Quote
Old 04-25-2005, 06:02 AM   #14994
teammpp's Avatar
Yep. Thanks. My bad. Its 1725g.
Old 04-25-2005, 10:07 AM   #14995
asw7576's Avatar
Thanks guys for minimum weight rule.
Here is another question: durability vs weight
I like my car to be bullet proof, so I start using longer Ti screws and find some ways to make my car stronger. The idea actually pay at bad crash and yet the car is able to continue racing. Even my buddy scratched his head after seeing the crash and my car is still running
Contradictorily, it costs me some weight, my car is close to 1900 grams !!! Does it affect the handling ? Or should I keep trying better setup for heavier car ?
Old 04-25-2005, 10:22 AM   #14996
gonzoY5's Avatar
Well that means you're lugging around 1/2 a Pound more on your car, which I'm sure means the handling/acceleration/braking of the car will change. How much, I don't know.
gonzoY5 is offline   Reply With Quote
Old 04-25-2005, 12:11 PM   #14997
Toma2525's Avatar
Trouble! I can't figure out what could be wrong. Under initial acceleration, my MTX3 bolts to the right. It is undrivable. I checked the belts thinking that could be it. All good. Then I noticed that my rear differential was "oily", like it had leaked. Could this be it? I am planning a rebuild of the rear dif. Any input would be appreciated. Thanks.
Toma2525 is offline   Reply With Quote
Old 04-25-2005, 12:13 PM   #14998
Derby Bros Racing's Avatar
check the following
trim
toe/camber
wheel bearings
servo horn may have moved or have been stripped
go one by one until it's solved
Derby Bros Racing is offline   Reply With Quote
Old 04-25-2005, 12:21 PM   #14999
cdelong's Avatar
check shock lengths, droop & free suspension movement. rebuild shocks, unbolt sway bars and ensure the suspension drops on it's own without any help or force.
cdelong is offline   Reply With Quote
Old 04-25-2005, 12:40 PM   #15000
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I had this problem before, check the brake pulley. It may not be tight causing the car to veer left or right. Your diff shouldn't be leaking though.
Racing4Evo is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
