Old 07-05-2005, 12:14 PM   #106
Trader Rating: 16 (100%+)
Originally Posted by asw7576
Sonik dude ..... how come your JP FX is silver body and mine is black ??
Very very interesting question....yeah, how come?
Old 07-05-2005, 12:17 PM   #107
sonik's Avatar
Send a message via MSN to sonik
Originally Posted by Top Gun 777
Hi Sonic.
I don't write articles-my english is sucks and have no time for it.
i have berrely time to work on new projects. if you go through my posts defenetly you will find some usefull info (it is 1500 posts).
I like O'Donnell fuel (to compare for what I have run so far and what is available on our market), it doesn't leave any resedue, keep engine clean even without after run oil, I never use after run oil, I never clean my motors till I need to change something-I am too leasy for it. It is not I recomend to do the same, it just what I am doing and never have had problems like rust or varnish.
I run about 60-80 gallons of O'Donnnel fuel since I use it-have no problem with it at all.
Edward
only just noticed your post edward thank's for your help, not to mention everyone else thats helped me in this thread
sonik is offline   Reply With Quote
Old 07-05-2005, 12:21 PM   #108
sonik's Avatar
If he is correct-yes, you are right. But I will take to concideration-yuo are in UK where is himudity 120% and it means your motor is sucking too much water with air while it is working. Here in California our himudity level is about 30-50% and we don't have this problem. Oxidation process going much faster when temperature is higher then ambient, so it is possible that rusting process began during the first start-it just assumption, not a statment. Actualy rusty marks on corod telling me that oxidation was during the run, not in storing process. If you store engine with water present-only steel parts will rust, Aluminium will stay clean. As I saw on picture it is that there was a flow which brought rust on aluminium parts.
Edward
thanks for that i never thought about the relative humidity, you could be correct , seems logical anyway . so people in the uk should take more care when leaving unburnt fuel in their engine's
Old 07-05-2005, 12:23 PM   #109
sonik's Avatar
aint got a clue ??? you jp expert's tell me , could it be a new thing ?
Old 07-05-2005, 12:33 PM   #110
stefan's Avatar
Send a message via AIM to stefan
Hi Sonic.
Edward
..and I thought you liked my fuel
Btw, over here I'm running Tornado fuel and this crap turnes my engines black inside. No deposits, just black metal. Looks like cheap, impure methanol. I guess I'll start looking for a source of nitromethane again....
stefan is offline   Reply With Quote
Old 07-05-2005, 01:37 PM   #111
Jye
Have you tried blue thunder?
Jye is offline   Reply With Quote
Old 07-05-2005, 01:47 PM   #112
stefan's Avatar
Who, me?
I did try it in the states, but didn't like it.
I ran O'Donnell until I made my own fuel.
O'Donnell is good stuff but not available here.
Old 07-05-2005, 02:04 PM   #113
M7H
M7H's Avatar
Originally Posted by stefan
Who, me?
Try Runnertime fuel......
It's Italian just like the fastest engines.......
http://www.runnertime.com/
Serpent
M7H is offline   Reply With Quote
Old 07-05-2005, 02:11 PM   #114
Sow&Steady's Avatar
You've got the "stock" version. The full option version has the ceramic bearing, black body and red paste in the crankshaft.
The porting are all exactly the same.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 07-05-2005, 02:20 PM   #115
sonik's Avatar
i have the paste in the crankshaft
you can see a bit of it in this pic,
, doe's that explain the black and silver crankcase business ?
Old 07-05-2005, 02:24 PM   #116
Sow&Steady's Avatar
i have the paste in the crankcase , doe's that explain the black and silver crankcase business ?
The box says "Stock Version". There are two stock version if I believe. One which has a kinda "straight" head, white body, no paste in the crankshaft.
The other "stock" option does not have the ceramic bearings and the darkened crankshaft but still has the red paste in it.
Old 07-05-2005, 02:25 PM   #117
Sow&Steady's Avatar
Right, it looks strange but maybe you have the standard JP-FX.
Old 07-05-2005, 02:36 PM   #118
sonik's Avatar
Sorry, but I think it'll be cheaper to buy a new engine.
Or you should probably consider replacing the bearings, try to save the crank and get a BRB piston/sleeve set from Palmaris Racing.
where can i get these palmaris racing piston and sleeve's ?
i take it they better than the jp one's ?
are they a direct replacement for the jp piston and sleeve?
Old 07-05-2005, 02:50 PM   #119
EdwardN's Avatar
www.palmarisracing.com here is web site were you can order all neccessary parts.
On contact page there is name Geoff Catchpole, shot him email and he will be able to help you. He is our rep in UK and Europe.
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 07-05-2005, 03:48 PM   #120
sonik's Avatar
in the mean time , any idea's as how to get this out ?
.21 onroad engine - hand-ported factory engine GlennCauley R/C Items: For Sale/Trade 2 02-25-2008 11:52 AM
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
