jp 12 engine horror >
jp 12 engine horror
jp 12 engine horror
Old 07-06-2005, 10:10 AM
  #136
EdwardN's Avatar
Actiualy from what I see only the case, backplate are useble-the rest will go to the trashcan. All steel parts yuo better dump it and don't even think to polish them-all parts inititaly ground and now rusty, you can make them shiny, but all tolerances will be lost.
To get new cranck, new P/S set, new bearings-it will be cheaper then new engine, but I am not sure if it is worse it.
Edward
BTW, there is some acid which will clean all rust out, don't remmeber the name of it, but will go to the lab now and later will give you the name.
EdwardN is offline
Old 07-06-2005, 10:15 AM
  #137
EdwardN's Avatar
It is Oxalic Acid. Please if you use it, use with respect-it is acide and use protective equipment. It will clean out all rust from your parts.
Edward
EdwardN is offline
Old 07-06-2005, 11:24 AM
  #138
cdelong's Avatar
Edward
keep it off your skin. it is easily absorbed into your bloodstream and will rock up in your kidneys. bad stuff!
cdelong is offline
Old 07-06-2005, 11:35 AM
  #139
asw7576's Avatar
How about Autosol polish ?? Is it dangerous .... don't want that craps go inside my bloodstream either. My lungs are already contaminated with nitro gas.
asw7576 is offline
Old 07-06-2005, 11:58 AM
  #140
jrabbito's Avatar
Hey Corey,
Thansk for the info. You are correct. Hopefully we will see you up in Hamilton again soon. If not see you at the Great Lakes Challenge!
Cheers,
John
jrabbito is offline
Old 07-06-2005, 12:09 PM
  #141
EdwardN's Avatar
Hi Corey.
This is why I sad it is acide and should be treated with respect-all neccessary safety precations need to be taken-respirator, latex gloves, glases etc.
If you search over the Internet, you will find some info:http://alsnetbiz.com/homeimprovement/oxalic_acid.html
We use it a lot in our company to clean some rusty stuff-textile is all about water and temperature.
Edward
EdwardN is offline
Old 07-06-2005, 12:24 PM
  #142
cdelong's Avatar
Originally Posted by jrabbito
Hey Corey,
Cheers,
John
I'm planning on coming the 16th and bringing some more racers along! I'm sticking with 1/8th and letting my buddy run my TC.
cdelong is offline
Old 07-06-2005, 12:41 PM
  #143
Francis M.'s Avatar
Wow did you open the engine before breaking it in. Ive never seen that much rust and resedue develop one day.
Francis M. is offline
Old 07-06-2005, 12:46 PM
  #144
jrabbito's Avatar
Great news!! See you in 10 days then Corey!
John
jrabbito is offline
