Old 06-29-2005, 08:23 AM   #1
ntc3freak's Avatar
Talking discharging ni-mh tx and rx packs......
question is....how???
ntc3freak is offline   Reply With Quote
Old 06-29-2005, 08:26 AM   #2
cdelong's Avatar
get a 12v automotive light bulb rated at ~ 1.0 amp. Wire the bulb up to a spare connector and hook the pack up and leave it on till just before the light goes out. It takes quite a while, but you don't want to overheat the pack discharging it a a high rate.
cdelong is offline   Reply With Quote
Old 06-29-2005, 09:16 AM   #3
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Why you want to discharge a ni-mh pack ? ...
Im using ni-mh packs on my TX (1500mah) and my rx (1800mah) for about 2 and half years now and NEVER cycled them ... and no one single issue with batteries so far ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 06-29-2005, 09:31 AM   #4
Try this.
Very good checker/discharger for tx and rx batteries
http://www2.towerhobbies.com/cgi-bin...&I=LXEYM6&P=ML
XrayEye is offline   Reply With Quote
Old 06-29-2005, 10:15 AM   #5
dct147's Avatar
1 side question, what`s TX & RX?
Also, is it true that Nicd chargers can charge Nimh batteries?
Tabushi ,
U`ve been using Nimh batteries and never had to discharge them? cool!
Even if u`ve only used let`s say, 1 - 2 hours of practice, do u still just charge them after?
Thanks for the help guys!
dct147 is offline   Reply With Quote
Old 06-29-2005, 10:33 AM   #6
TX = Transmitter
RX = Receiver
Old 06-29-2005, 10:49 AM   #7
gonzoY5's Avatar
Nimh batteries don't need to be cycled like nicad ones do.
gonzoY5 is offline   Reply With Quote
Old 06-29-2005, 10:52 AM   #8
Tabushi's Avatar
Tabushi ,
I just use a fast charger (http://www.horizonhobby.com/Shop/ByC...?ProdID=HAN114) every weekend ... if i practice just a couple of hours i pack everything, go home and dont open my stuff until next week ... that for my cars and planes ...
Old 06-29-2005, 11:37 AM   #9
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I like to discharge mine now before a race and fully charge it so I know I got max juice in it.
Just like they said get an 1157 (I think thats the number) automotive dual filament bulb. You can get them at wal-mart or anywhere automotive for $2 dollars or less.
I then got some alligator clips. I already made an adapter for my packs. I used some speaker wire terminals. Then I just clamp on the clips and discharge it while its on the vehicle like I charge it.
You can find this tip somewhere in rcnitro or rccaraction. Just dont let the bulb dim.
Artificial-I is offline   Reply With Quote
Old 06-29-2005, 11:53 AM   #10
dct147's Avatar
Thanks guys.
Can Nimh batteries be charged with a Nicd charger?
cause that`s what i`m doing now from the tip of my lhs owner whom i suspect might just wanna rip me off as i was desperatly looking for a budget slow charger.
am worried about it.
Old 06-29-2005, 12:20 PM   #11
Trader Rating: 16 (100%+)
Thanks guys.
I would like 99% you cannot use Nicd charger to charge Nimh, like using 93 octane gasoline on your Nitro RC car....nothing is good will happen.
A Ok nimh/nicd charger like this MRC Super Brain 959 Charger is around $45, can charge both mostly use batteries, with a lot of other function, and if you cannot even want to spend $45 for a OK charger, RC is really not for you.
http://www2.towerhobbies.com/cgi-bin...&I=LXAVN1&P=ML
On the original note, I too, used my Tx and Rx for 2 plus year now.......never cycle or discharge charge or whatever to peak my packs.......those are for RADIO use, I don't use those batteries to power my NITRO car.......as long as I see full 10.2V and 6.8V, I am happy.............and I don't discharge them before charging, Nimh suppose has no memory problem like Nicd.
Old 06-29-2005, 12:22 PM   #12
Data's Avatar
Thanks guys.
hope you find the answer here, good luck.
Data is offline   Reply With Quote
Old 06-29-2005, 12:29 PM   #13
Rapid Roy's Avatar
You can charge NIMH batteries with a trickle or wall type charger no problem. You can get one with leads to charge both your radio and receiver batteries at the same time. As long as you radio has a charging plug built into it. I got mine for $13 or so. Just plug everything in the night before you run and you won't have any problems. If you need a fast charge though, you are going to need somthing like the MRC that Rookie recommended.
Rapid Roy is offline   Reply With Quote
Old 06-29-2005, 12:53 PM   #14
cdelong's Avatar
a little tech info on Nimh batteries-
http://www.promatchracing.com/rs4ins.htm
http://www.promatchracing.com/faq.htm
These articles are from an industry leader- www.promatchracing.com
Nimh batteries will perform better with some occasional maintenance. I know one article is for GP3300's, but the other is for micro cars which use the same battery packs we use for receiver packs.
Old 06-29-2005, 01:16 PM   #15
dct147's Avatar
Thanks for all your helpful replies guys,
Guess i`m ok with it for now as my charger`s a trickel wall charger.
I will invest in a good proper charger. but not now as my budget is tight.
Who says RC`s not for me EH!
Anyhow, thanks guys, really helped me out!
Discharging 5 cell packs....?!?! Island Losi Electric On-Road 2 01-29-2008 04:10 PM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 11:58 PM
discharging whilst packs on a tray??? xray racer Electric On-Road 8 08-27-2005 10:29 AM
Discharging receiver packs revzalot Nitro On-Road 3 04-08-2005 03:01 PM
Discharging Stick Packs f2000racer Electric On-Road 7 01-15-2005 01:38 PM
