Old 07-08-2005, 09:23 AM   #31
New_Toasted's Avatar
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
Since we're talking about batteries here I have one question, what would be good settings (amps, peak mV) to use when charging
1) a 800 mAh 5 cell RX pack
2) a 2000 mAh 8 cell TX pack
And also, what determines how many amps the pack can take, the number of cells or the capacity?
New_Toasted is offline   Reply With Quote
Old 07-17-2005, 11:58 AM   #32
dct147's Avatar
Hi all,
i`m intending to discharge my rx standard 6V 1100mah batts. but not intending to get a discharger yet. there`s a way using the light blub to monitor the discharge of the batts right? how do i do it? do i chack by looking at the bulb grow dimmer or just drain till there`s no more life left to light up the bulb.
Most important, what kind of buld should i get to do that? what voltage or watts should i be looking at?
Thanks a bunch.
dct147 is offline   Reply With Quote
Old 07-17-2005, 12:24 PM   #33
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
1amp discharge
1157 automotive bulb (dual filament auto bulb)
http://rcnitro.com/rn/articles/gs_batteries2.asp
Goto the middle section "Discharging" for more explanation and itll show the bulb and how to wire it.
Artificial-I is offline   Reply With Quote
Old 07-17-2005, 12:47 PM   #34
Trader Rating: 28 (100%+)
Leave the bulb on until you see the light dim down alot. Then take it off. Don't leave it on until it goes completely out.
jbrow1 is offline   Reply With Quote
Old 07-17-2005, 01:10 PM   #35
asw7576's Avatar
If you forget to remove it ( the light is completely out ) you should give some charge. NiMH battery need some volts before storing. You can discharge and recharge it again to get maximum runtime.
For Rx batt ( AAA 850 ) : 0.8A - 1A charge ; 1A discharge ; 25mV delta peak
For Tx batt ( AA 2300 ) : 1.2 A charge ; 1A discharge ; 25mV delta peak
I use 12V double filament automotive bulb ( usually for car left/right lamp signal ). One bulb equals 1 amp. It's safe for discharging Tx/Rx without frying the cables.
Old 07-17-2005, 01:13 PM   #36
dct147's Avatar
Thanks for the info.
I have read and understand. but i`m not sure what bulb is that still.it`s called a 1154 bulb at 1amp. i don`t see anything about amp at my hardware stores here. only about Voltage. is there anything about voltage i should look at?
also, was doing the calculation for the charge time about the input. my charger only shows options of AC output - 4.8v , 6v, 9.6v, 12v.
another part shows AC input - 100-120v/220-240v 7W.
i don`t quite understand it. i`m using a trickel charger.
Could anyone help me out pls?
Thanks a bunch....
Old 07-17-2005, 01:36 PM   #37
Moderator
Thanks a bunch....
It should be called a dual filament automotive bulb.
The part number is 1157. Its a very standard auto motive bulb I believe used for the brake lights if that helps any.
Old 07-17-2005, 01:39 PM   #38
dct147's Avatar
Thanks Artificial-I.
I`ll try finding it at my hardware store!
Cheers!!
Old 07-17-2005, 01:48 PM   #39
dct147's Avatar
asw7576,
Thanks for your help.
What is 25mv delta peak?
Old 07-20-2005, 10:27 AM   #40
dct147's Avatar
Hi again guys,
I`ve finally got my 12v single filament bulb, and it proves very effective.
didn`t say anything about the amps though. but as long as it serves it`s purporse.
anyway, i`m now looking to discharge my glow heater rechargable battery. it`s a standsrd GP 3300 C size battery. how should i discharge it? i tried taping the red wire to the positive side and the black to the negative. bulb didn`t light up.
Any tips on this?
Old 07-20-2005, 11:03 AM   #41
Moderator
Hi again guys,
Any tips on this?
Might already be dead or it might just not have touched correctly. Also could be the bulb wiring / soldering itself is a perhaps not fully connected.
Retry another battery to make sure your bulb is discharging.
Yeah they probably wont say 1amp on the package , but these bulbs generally take about 1amp.
Old 07-20-2005, 11:12 AM   #42
dct147's Avatar
Heater`s fine. tested it on a plug. it glowed.
Bulb`s fine. tested it with my Rx batts.
Probably didn`t get a full connection.
Is there a rule where the black and red should be at? + -?
Old 07-20-2005, 11:18 AM   #43
Moderator
Red is positive + , black is negative -.
Old 07-20-2005, 11:38 AM   #44
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally Posted by XrayEye
Try this.
Very good checker/discharger for tx and rx batteries
http://www2.towerhobbies.com/cgi-bin...&I=LXEYM6&P=ML
says right in the product description can't be used on transmitter packs...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-20-2005, 11:51 AM   #45
Rapid Roy's Avatar
One cell is only 1.2 volts. The bulb is rated for 12 volts which is why you arn't getting it to light up. I haven't figured out a good way to discharge the glow starter yet. I have used a flashlight bulb and simply pluged it into the end of the glow starter. The other way is to use a messed up glow plug that still glows and plug it in. The best way would be to use a discharging tray like the electric guys use. I have really given up on discharging my igniter battery though. A couple of years ago I picked up a 5000 mah igniter made by Hobico. That sucker has a lot of juice. I race with my son, and I have had race days where both cars were giving me engine problems and I had the igniter on a LOT and havn't had any problems with it running down. I drained my dual stick pack starter batteries twice in the process. I have since gone to a 12 volt gel cell on my starter. Heavy as heck, but no wories on running out of power.
Rapid Roy is offline   Reply With Quote
Discharging 5 cell packs....?!?! Island Losi Electric On-Road 2 01-29-2008 04:10 PM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 11:58 PM
discharging whilst packs on a tray??? xray racer Electric On-Road 8 08-27-2005 10:29 AM
Discharging receiver packs revzalot Nitro On-Road 3 04-08-2005 03:01 PM
Discharging Stick Packs f2000racer Electric On-Road 7 01-15-2005 01:38 PM
