Old 06-27-2005, 02:13 PM   #16
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Im just going by what he said and if it cant idle its rich somehow.
Artificial-I is offline   Reply With Quote
Old 06-27-2005, 02:17 PM   #17
stock setting is 1 turn from full open, which is where it's at now.
I just got done taking the carb off the motor and making sure all was well and it looks to be. Now I'm wondering if this isn't and idle problem but a clutch problem.
jcaudill is offline   Reply With Quote
Old 06-27-2005, 02:29 PM   #18
Moderator
Well listening to the car would help me figure that out. But im pretty sure when you say the car shifts into second , that alone makes me believe that the rpm is too high.
Your clutch might also have some trouble if you know how they go or have the manual it shouldnt be too hard to dissamble and inspect that to knock that out of the way.
Also when you re-install the carb , put a lot of pressure down on it when tightening the car screw this will help make a tight seal.
Old 06-27-2005, 02:32 PM   #19
Oh, well I should emphasize that it's definitely not running that fast anymore. It's running very steady. It's just all 4 wheels are spinning while it's doing it
Old 06-27-2005, 02:41 PM   #20
factory racer's Avatar
try setting the idle trim on ur controller lower....c if that helps...
factory racer is offline   Reply With Quote
Old 06-27-2005, 03:26 PM   #21
So far I haven't been using any of the electronics. So that shouldn't be a factor... should it?
Old 06-27-2005, 05:46 PM   #22
Send a message via AIM to The evo guy
hey hows it goin' i had the exact same problem and after listening to some barry white i disassembled the tranny and the clutch was loose and the tranny pinion was too tight(nearly no play) then i put it back snuggly not tight and it ran just fine
The evo guy is offline   Reply With Quote
Idle Tuning Woof Nitro Off-Road 18 01-09-2008 07:37 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 07:04 PM
tuning trouble Woody26 Electric Off-Road 2 01-04-2007 04:07 AM
beginner questions re: car tuning and motor tuning! Captjono Rookie Zone 5 02-19-2005 12:01 PM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
