Old 06-24-2005, 02:52 PM   #1
afm
afm's Avatar
Default Batteries and Digital Servos
Can anyone tell me if an 850mah AAA battery pack would last an hour main final, when used with 2 digital servos (Ko Propo 2343 and HiTec HS-5475 HB), over a TM G4 Touring Nitro Car.
AFM
afm is offline   Reply With Quote
Old 06-25-2005, 12:14 AM   #2
asw7576's Avatar
Nope. 45 minutes max with two digital servos. Another problem is transponder weak signal.
My friend use two erg vx ( 13kg non digital ) and barely make it 1 hour.
Old 06-25-2005, 12:21 AM   #3
asw7576's Avatar
OMG.... your main final is 1 hour ??
Let me suggest for you : Buy li-po battery. Light weight, Big Capacity and more punch.
Old 06-25-2005, 04:33 AM   #4
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I made an hour long main with two analog servos on a 730mah pack. If you are worried, there are longer life batteries available. I have seen AAA nimh upt to 1000 mah. I believe GP has a 900 or 950 out right now.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-25-2005, 06:26 AM   #5
Seisick's Avatar
alfonso, ebay has aaa 1100 mah. enough for an hour!
saludos
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 06-25-2005, 07:05 AM   #6
richey's Avatar
Send a message via MSN to richey
If your battery is charged properly you shuld have no problem making the whole hour with an 850. We have been running hour long mains in Las Vegas for 2 years and have had only a few not make the hour long main.
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 06-25-2005, 08:57 AM   #7
afm
afm's Avatar
Thanks to all of you guys. I guess It's time to search for a high capacity AAA pack.
AFM
Old 06-25-2005, 08:59 AM   #8
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Hey guys I came across an interesting thought. I went to http://www.energizer.com/products/lithium/ to check out their rechargables. Basically looking into the AAA pack.
I then went to their lithium batteries. They say they weigh 1/3 less than standard alkalines. So im guessing this would be the ultra lightweight battery pack.
It doesnt say you can recharge them but I wonder if you could with an appropriate charger. I have no clue what that would be, li-poly charger?
I know your not supposed to charge alkalines but people still do that.
Also the power output says they last 7X longer than regular alkaline. So im sure their also much better than the rechargables.
If anything I wonder how much runtime one could expect it might be worth buying a set or two and running that for the season. I figure if you get 1 run times or something with rechargables then it should be 7 hours for the lithiums?
Which is a good amount of runtime , at least for me. Im going to look into this further, cause this might be the way to go and you dont risk running out of juice during long mains.
Artificial-I is offline   Reply With Quote
Old 06-25-2005, 10:22 AM   #9
Jye
do the mah's on battery packs indicate some type of duration of thier run time?
Jye is offline   Reply With Quote
Old 06-25-2005, 04:42 PM   #10
Moderator
Yes.
Old 06-25-2005, 08:00 PM   #11
Data's Avatar
mAH is to indicate how much charge a battery normally can hold at full charge. actual run time depends on how much charge the electronics on your car consumes.
Data is offline   Reply With Quote
Old 06-25-2005, 10:20 PM   #12
Jye
How much mah's do the batteries you guy's use have, and do you used nicd or nimh?
Old 06-26-2005, 02:20 PM   #13
Greg M's Avatar
Can someone post a link to the 1100mah AAA's on ebay as I can't find them.
I run 800mah packs with a KO 2343 and 2344 and I'm getting just over 3, 5 minutes runs with them. One pack is only 2 months old!! I run a PT off it as well for the little they drain, so am badly after more capacity and had looked at going Lipo, but I'm unsure if a Lipo pack will fit in my Serpent 710.
Both my 800mah packs get just over 600mah in them, has anyone else had problems with theirs? What charging methods are people using, amps and cut offs etc.
Greg M is offline   Reply With Quote
Old 06-27-2005, 03:22 AM   #14
asw7576's Avatar
Charger : any Ni-Mh charger like LRP Pulsar Competition, CE GFX
Charging Amp : 0.9 A
Delta Peak : 10 - 25 mV
Charging Style : linear
AFM, a friend of mine said AAA 850 is enough for 1 hour final if you charge them from 0 mAH capacity . He has a G4 with 2 x 8.1 kg digital servos.
Old 06-27-2005, 03:33 AM   #15
Greg M's Avatar
I'll increase my peak cut off, think its about 8mv. My 3300 are at 12mv and will sometimes cut off on the temp sensor, so thought receiver packs would be the same.
FUTABA Servos Digital Brushless BLS451 and Digital S9351 SCUBA STEVE R/C Items: For Sale/Trade 8 11-11-2007 06:18 PM
Hitec 925MG, 625MG servos, digital or non digital Cain R/C Items: Wanted to Buy 2 03-09-2007 03:17 PM
ko pro po digital servos teamatlas R/C Items: For Sale/Trade 1 09-15-2005 04:26 PM
digital servos judge10tpt Electric On-Road 1 06-27-2005 05:31 PM
digital servos murfy Australian Racing 5 05-27-2004 06:12 AM
