Old 06-24-2005, 01:38 PM   #1
Send a message via AIM to NitroNubee
Default Please Help! 2 speed MTX-2 question
HELP! The thingy won't come out of the other thingy! I am not sure what it is called. The tranny part (D0211) will not come out of the housing that is attached to the 43T spur gear. Does anyone have any advice on how to get it out? I have attached a pic. The arrow is pointing to where it is hanging up.
Thanks VERY much for the help!!
NitroNubee is offline   Reply With Quote
Old 06-24-2005, 01:57 PM   #2
I am guessing here... cause its been awhile since I have had a MTX-2... but I think that possibly the set screw has worked its way out... and has wedged in between the housing and 2 speed.......
R40LV is offline   Reply With Quote
Old 06-24-2005, 02:36 PM   #3
That is a pretty good guess, R40LV! Except, would that still be the case if I can still get to the set screw? I was able to back it out, but not through to the access hole. And, I can turn it in until I see it in the hole where the shaft goes. I can see 2/3 of the edge of the D0211 and do not see any groove or anything where something has rutted the piece. Something has to be catching it. Kevin, at Ace, suggested drilling a hole in what I thought he meant was the 2 speed. Has anyone else heard of that? I do not feel comfortable doing that just yet.
Thanks in advance for a solution!
Old 06-24-2005, 04:38 PM   #4
007kel's Avatar
Send a message via AIM to 007kel Send a message via Yahoo to 007kel
That looks like a finger type two speed, where a piece of metal pulls out to grip the 2nd spur gear in order for the two speed to engage. Your set screw (2 speed adjustment) retains a spring and a ball bearing that will push that finger out to engage 2nd gear. You may have that "finger" sticking out (the spring might have pushed it too far and has become wedged not allowing the finger to come back into the inner housing) which is not allowing you to take the two speed apart.
KO PROPO HELIOS...yeah that's what I have left after leaving RC.
www.foundrycc.com
Instagram: 7kel
007kel is offline   Reply With Quote
Old 06-24-2005, 08:25 PM   #5
Ahhh, very good, 007kel. That makes sense. Now, how would one go about fixing the problem? I have stared at it for hours (and that didn't work ), but have not figured out what to do.
Thanks for the replies! Keep the ideas coming.........
Old 06-29-2005, 09:05 AM   #6
Thanks for all your ideas. I finally got it out last night. Special thanks to Robbie at Mugen. He suggested using a cleaning solvent to get out whatever debris was in there. I wasn't sure what to use so I broke out the WD-40. After 2 days of spraying, squirting, blasting with compressed air and a little screwdriver surgery, it came out. It looks like the "finger" was a little loose and sloppy. The housing looked good. I just blast cleaned it with my new air gun cleaner (see thread "cleaning our cars" on this forum ). FORTUNATELY, I had a spare D0211 in my parts box! So, I will finish assembly tonight and hopefully fire it up this weekend!
Thanks again, RCTech Forum!
hpi speed control question ralphee6 Electric On-Road 2 10-07-2004 08:47 PM
Two-Speed Question: DAUER962 Rookie Zone 1 05-04-2004 03:00 PM
2 speed question 2Hard2Handle Nitro On-Road 0 08-03-2003 10:28 PM
2 speed question on TC3 alucard13 Nitro On-Road 17 05-02-2003 02:07 PM
2 speed vs 1 speed on road 1/10 question DjCalvin Rookie Zone 7 04-27-2003 03:33 PM
