Old 06-24-2005, 11:52 AM   #1
Default Hump Batterys
Looking for a charger for this if you could oint me to the right directions or recomend something good.... Is it true that you get more response compared to AA batterys?
BeBop is offline   Reply With Quote
Old 06-25-2005, 10:49 AM   #2
dakrat's Avatar
its all about the voltage. more response? no! its all about the voltage, same number of cells AA would be better because it has 1.5v each cell. rechargeable ones only has avg of 1.2v
dakrat is offline   Reply With Quote
Old 06-25-2005, 11:27 AM   #3
nitrodude's Avatar
Most RTRs come with a 4 AA pack, if you use 4 AA rechargeable batteries you get less volatage, and the servoes are a little slower. Rechargeable 1.2v, alkalines 1.5v.
If instead you use a 5 AAA rechargeable, you get 6v, versus 4AA 4.8.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 06-25-2005, 11:52 AM   #4
dakrat's Avatar
if ur looking for a charger just for the rx packs then no need to buy expensive charger. if u want u can buy a 10 dollar wall charger but it takes forever to charge. u can try mrc superbrains
Old 06-25-2005, 03:13 PM   #5
dct147's Avatar
i`m looking for batteries too.
should i go for the flat or hump pack? ( don`t think would make much of a difference, or is there?)
also, what should i be looking out for? as in, the voltage or amp or others?
is there a standard voltage?
dct147 is offline   Reply With Quote
Old 06-25-2005, 04:41 PM   #6
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
flat or hump pack are dependant on your application some cars need a flat pack like the R40 others like the Savage require a hump pack since the flat pack wont fit.
other wise they are the same voltage wise
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 06-25-2005, 04:57 PM   #7
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Hes actually correct.
Straight from Steve Ponds Nitro Battery Article that ive burned into my memory.
"Rechargeable packs improve performance. Although 4 alkaline cells have as much voltage as 5 rechargeable cells, the alkaline cells can't deliver as much punch when the power drain is high. That means you won't get as much speed or torque from a servo powered by alkaline batteries as you would from one with a rechargeable pack. "
Artificial-I is offline   Reply With Quote
Old 06-26-2005, 12:45 AM   #8
dct147's Avatar
Thanks for your replies.
What should i be looking out for when i`m purchasing my batteries?
I`m looking for a longer lasting pack.
1100mah, is that on the higher end?
I`m totally new to this battery thing, could u point out the right things to be looking at when purchasing?
Thanks alot guys!
Cheers!
Old 06-26-2005, 10:43 AM   #9
Moderator
1200-1500 is about the highest from the standard name brand packs.
Old 06-26-2005, 11:18 AM   #10
dakrat's Avatar
ofna sells some 1500s and really cheap. i use them on my monster truck and it would last all day!
Old 06-26-2005, 11:53 AM   #11
dct147's Avatar
Thanks guys,
Haven`t seen 1500`s here in Singapore so far. highest i`ve seen so far is only 1200`s.
But anyway, thanks for the help.
Old 06-27-2005, 08:38 AM   #12
dct147's Avatar
If i were to use just 1 pack of 1100`s, would it be enough for an average day of practice?
Old 06-27-2005, 12:39 PM   #13
factory racer's Avatar
yes it would be enough....................ofna makes a 1400 mah nimh battery flat pack ........its amazing it lasts forever......
Mike
factory racer is offline   Reply With Quote
Old 06-27-2005, 02:14 PM   #14
Moderator
Yeah I have the ofna hump pack. Holds it charge well.
WTB: Rx hump packs XXWoodmanXX R/C Items: Wanted to Buy 1 08-04-2008 02:42 AM
**Hump Receiver Pack** 15.00 lynell90 R/C Items: For Sale/Trade 1 05-21-2008 11:35 AM
Two 1200mah rx hump packs $25 for both lp1066 R/C Items: For Sale/Trade 3 08-29-2006 08:23 PM
FS-M8, Charger, hump pack JEXTEL R/C Items: For Sale/Trade 13 04-24-2006 07:41 PM
Which hump pack? corvettecrazy Electric Off-Road 3 04-26-2004 03:26 PM
