Old 09-24-2013, 09:04 AM   #1
tonylunatic's Avatar
Trader Rating: 45 (100%+)
Default IGT8F - International GT8 Federation
WWW.IGT8F.COM
IGT8F mission statement "To unite all GT racers, and promote On-Road racing through the GT class"
[email protected]
Tony Luna
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is offline   Reply With Quote
Old 09-24-2013, 09:06 AM   #2
British Menace's Avatar
Good move tony on the thread.
I like what your doing .....
Keep up the good work sir.
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 09-24-2013, 12:18 PM   #3
Grenade10's Avatar
Trader Rating: 37 (100%+)
I'm building a 1/7 scale DM-One for the spec class. Any questions on the build let me know.
I should post pictures as I am going through the car. Really interested to see how the longer car works and what changes work with it.
Mark
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 09-24-2013, 03:32 PM   #4
MantisWorx's Avatar
Trader Rating: 28 (97%+)
we should move onto the IGT8F forum for the in depth stuff and to get it rolling before the new season.
MantisWorx is offline   Reply With Quote
Old 09-26-2013, 04:09 PM   #5
VP-Pro USA
Has a Limited Time IGT8F Special Combo Offer on its GT tires, check it out:
http://www.vpprousa.com/rc-wheels-tires/gt.html
Old 09-26-2013, 04:28 PM   #6
Awesome GT8 racing video.
https://www.youtube.com/watch?v=v7-Y...e_gdata_player
Old 10-03-2013, 04:27 PM   #7
afm
afm's Avatar
Default 7th INTERNATIONAL PACIFIC CUP LIMA - PERU March 7 – 9, 2014
RULES & REGULATIONS 1/8 NITRO GT
1. – Car:
Any 1/8 and 1/7th scale car, with shaft transmission system, manufactured originally as a GT car for this category, or derived or converted from an off-road model car (Buggy or Truggy), provided that they are with shaft transmission. Models with belt transmission systems are not allowed.
Overall Dimensions:
• Maximum length (includes Body): 730mm.
• Maximum width (includes Body): 336mm.
• Wheelbase: From 270mm to 361mm.
• Width to outside of wheels : 310mm .
• Maximum height: 300mm measured from the floor (with the suspension fully compressed) to the highest point (excluding the receiving antenna of the radio).
• Minimum weight: 3500grs. (Including battery and transponder, without fuel)
2. – Chassis:
Only Aluminum commercially available chassis with or without front kick-up. Carbon fiber or other composite material chassis are not allowed.
3- Engines:
Only engines from .21 ci (3.5cc) to .28 ci (4.6cc) which their retail list price on the international market does not exceed U.S. $ 300.00.
• Engines must be single - cylinder, two (02) strokes, normally aspirated, and air-cooled glow ignition type using Standard or Turbo plugs.
• No forced vacuum systems, liquid cooling systems, and carburetor pressurization systems (other than through the exhaust pressure applied directly to the tank of the vehicle).
• Any carburetor may be used, provided they keep a mandatory Venturi ( restrictor ) of 7.00 mm maximum diameter only (not allowed another lesser extent )
• May have a maximum of nine ( 09) ports, including the exhaust port (seen with the piston at its lowest position).
• No additional holes in the piston.
• It is not allowed the use of ceramic material in any part of the engine, except in the bearings.
• The internal engine modifications are not allowed. Engine should always be kept 100 % original in design and dimensions according to the manufacturer specs.
• The use of the recoil (pull start) is optional and can be removed or overridden if desired.
4. - Body:
Any closed body type " Gran Turismo - GT" , commercially available in the market and that fits the definition of vehicles in GT racing categories in real life : ".... a car that has no more than one door at each side and at least two seats situated on either side of the longitudinal center line of the vehicle, capable of being used perfectly legal on the road and then adapted to competition in circuits or closed routes " (should look like a real life car that could be driven on the street with a passenger) .
•As a 4-door sedan, the only body allowed is Kyosho Audi A4 DTM
•The body must be cut in the manufacturer's line.
•Only the front side windows maybe cut.
•It is allowed to cut a 100mm hole (constant radius) between the front windshield and roof for ventilation and fuel tank access.
•It is allowed to totally cut the rear windshield.
•It is allowed to cut a 35mm hole in the roof for the plug heater.
•Spoilers: Only one rear spoiler may be used. The rear spoiler must be attached to the body (Body) and not to the chassis.
•No added piece that gives advantage for cooling purposes or aerodynamic advantage or to change the original dimensions is allowed.
•The engine cylinder head must not protrude from the Body.
•Car tires must not protrude from the Body, seen from above
5. – Gears: the use of a two (2) speed gear box is allowed.
6. - Radio and Servos:
Any type of radios and servos, but no electronic aids such as gyroscopes or Drift Box, etc., neither the use of active telemetry during competition is allowed.
7. – Brakes:
Free in terms of quantity and material, provided they are in the transmission shaft line.
8. – Differentials:
Standard type (satellite and planetary system only). Center differential is not allowed nor Thorsen, TCD and One Way type differential in either axis.
9. – Clutches:
Only centrifugal action 2, 3 and 4 legs clutches are allowed. They can be adjustable or non-adjustable. The use of Centrifugal – Axial push type clutch (Centax) is not allowed. The material of the legs is free.
10. - Fuel Tank:
The total tank capacity including filter and hoses should be maximum 150cc. Loose objects are not allowed inside the tank to comply with aforementioned capacity.
11. - Mufflers and Pipes:
Any pipe and header combination for motors from .21 to .28 are allowed.
12. - Tires and Rims:Only the use of tires that have been manufactured specifically for GT class and / or Rally Game 1/8 or 1/7th scale, and that otherwise complies with the following specs and features are allowed:
• Rubber, both natural and synthetic tires only . It is expressly forbidden to use foam tires.
• All tires must be black with the exception of side letters, which can be colored.
• The maximum width of the tire is 45 mm.
• Rims must have a minimum diameter of 75 mm and maximum 85 mm.
The rim - tire set must not exceed a maximum diameter of 110 mm.
• The minimum diameter of a tire set at any time during the race is 85mm.
• No traction additive applications to try to increase tire traction are allowed, either pasting them outside or applying them inside out.
13. – Fuel:
The fuel must have a maximum of 25% Nitro.
The following additives are strictly prohibited: Hydrazine 8N2H4), Hydrogen Peroxide, Toluene Propylene Oxide. Random test can be performed (at the discretion of the organization) without notice in the course of the competition.
RULES & REGULATIONS 1/10 NITRO TOURING 200mm
All IFMAR World Cup rules & regulations apply for this class.
HOPE TO SEE YOU IN LIMA IN MARCH
Best Regards
AFM
afm is offline   Reply With Quote
Old 10-10-2013, 01:31 PM   #8
modhobby's Avatar
Trader Rating: 25 (100%+)
Ok, we are excited to announce the official SPEC package is now available from the REDS USA Factory web site:
http://www.reds-racing-usa.com/on-ro...or-1-8-on-road
We look forward to being a part of a great solution to bring new drivers to on-road, myself included. Dealers, if you want to participate, please don't hesitate to contact me. More news coming soon.
-Alex
REDS Racing USA
modhobby is offline   Reply With Quote
Old 10-11-2013, 02:21 AM   #9
Awesome review of the Reds R5T engine by NeoBuggy.
http://www.neobuggy.net/mobile/#more-34781
Old 10-15-2013, 08:02 AM   #10
Grenade10's Avatar
Default Heart of America, last series race
I brought the spec Reds Engine combo and the VP spec tires to show the racers. Received positive feedback on how the class is coming together. Thinking 4 - 6 racers are planning on running the class next year.
Let several racers try the tires on their cars for the qualifiers and grip was good, just required some warm up. Wear was very good, so the tires should last maybe 2/3 weekends.
There was talk about getting out the Kyosho long wheel base cars, and the realistic bodies. So other than having my spec car done, it was a success this weekend.
Mark
Old 10-15-2013, 09:15 AM   #11
Mark
That is Awesome news Mark!! Glad you got everything in time
The weather done here has not cooperated with us the last 2 weeks. We have had to reschedule the first Winter Series Race twice now
On a positive side, let's guys get their gear in order before the Grand Prix in November.
Old 10-15-2013, 09:27 AM   #12
Default Race Ready IGT8F "SPEC" CAR
Old 10-15-2013, 09:58 AM   #13
djmorales's Avatar
Send a message via Skype™ to djmorales
Default GT
Looks spec tagler homie. That motor looks top notch can't wait for the Byron race in June
Serpent GT cobra leisurehours Raceway local racer /slow is fast
djmorales is offline   Reply With Quote
Old 10-15-2013, 11:36 AM   #14
jaratr's Avatar
@tonylunatic; More please sir.
AE Nitro TC3, Mugen MST-1, Mugen MRX-4 (sold)
jaratr is offline   Reply With Quote
Old 10-15-2013, 07:05 PM   #15
manny021803's Avatar
Thumbs up PORT JERVIS NY, HOT RACE EVENT
This event was 10/13/2013 port jervis rc on road track new york A-MAIN GT WINNER
NEW YORKERS RACERS TEAM(NYRT)
bruckner hobbies/sweep tire/desoto racing/bu-ku clutch
NYRT#4
NYRCC #124
manny021803 is offline   Reply With Quote
