Old 01-08-2014, 06:58 AM   #136
Doug M's Avatar
This is an unconfirmed and unofficial driver list based on info from many different sources.
Entry List
Doug M is offline   Reply With Quote
Old 01-08-2014, 07:03 AM   #137
Doug M's Avatar
This is an unconfirmed and unofficial drivers equipment list.
Drivers Equipment List
Old 01-08-2014, 07:11 AM   #138
Doug M's Avatar
We will have the speed trap set up on the long straight during practice and racing. We usually see the GT cars reach speeds in the mid 50's mph range. With the talent for this race I wonder if we will see a 60 mph speed on the long straight? I sure hope so!
Old 01-08-2014, 11:17 PM   #139
Originally Posted by rcmikel View Post
Congratulations Jaime.
Thanks my friend, good luck on the race. I hope to see you this year sometime if I get the nod from the wife
jneg is offline   Reply With Quote
Old 01-09-2014, 10:39 AM   #140
manny021803's Avatar
good luck guys!!!!jose bring thophy to ny ok
NEW YORKERS RACERS TEAM(NYRT)
bruckner hobbies/sweep tire/desoto racing/bu-ku clutch
NYRT#4
NYRCC #124
manny021803 is offline   Reply With Quote
Old 01-13-2014, 08:38 PM   #141
GT results from this weekend's FORGASS race at Homestead
The lap times were faster than last month's and it looks like the racing will be very intense this weekend. Records may fall! Safe travels to everyone making their way to Homestead.
desotoracing is offline   Reply With Quote
Old 01-14-2014, 09:33 AM   #142
Doug M's Avatar
I have caught my breath after directing the FORGASS Race at Homestead this past weekend. Joaquin said and I agree the track should be very fast for the Pan American International 1/8 GT Grand Prix this coming weekend.
We will have cooler temperatures which usually equates to more horsepower and even more traction. If this holds true we could see some record breaking laps from the great group of racers that will be attending.
For those of you traveling please be careful and I hope your trips are pleasant and drama free.
GT Nation you can look forward to one of the best events of the year!
Old 01-14-2014, 09:42 AM   #143
Doug M's Avatar
Default Rules reprint
Pan American Intíl 1/8 GT Grand Prix Rules
Homestead RC Raceway
January 17, 18, 19, 2014
CATEGORY GT 1/8 Pro:
1. - GENERAL
Participation in this category is for eighth and seventh scale with shaft drive transmission, with a front and rear geared differential that is manufactured or a conversion based on an off road buggy platform. Belt drive transmission models may not participate in this category.
1.1-Overall Dimensions:
Maximum length (includes Body): 730mm.
Wheelbase: From 270mm to 361mm.
Width to outside of wheels: 310mm.
Maximum height: 300mm measured from the floor (with the suspension fully
compressed) to the highest point (excluding the receiving antenna of the radio).
Minimum weight: 3500grs. (Including battery and transponder, without fuel)
1.2-It is the responsibility of the drivers to make sure the car is
within specified regulations throughout the race event. The race organization can check any car for compliance with the rules at any time during the event.
1.3-If a car exceeds the limits of dimensions after a race, the driver may be disqualified for that race.
2.-Body:
2.1-The body must be a closed body, commercially available type GT or Sedan. (An exception is allowed Ipanema body used in the
Championship 2010)
2.2-The body must be cut on the manufacturer's trim line.
2.3-Front side windows may be cut out. (If sedan, ie
4-door only will be able to cut only the front side windows)
2.4-A circular hole (constant radius) not greater in
100mm diameter may be cut, between the front windshield and roof for fuel tank opening.
2.5-Rear windshield may be totally cut out.
2.6-A circular hole not greater than 35mm may be cut for glow plug access.
2.7-A circular hole not greater than 10mm may be cut for antenna exit.
2.8-Rear wing must be attached to the body and not the
chassis.
2.8.1- Rear wing cannot be higher than highest point of roof line.
2.9-No other parts may be added to the body to give cooling, aerodynamic or change the original dimension of the body.
2.10-The cylinder head will not protrude from the body.
2.11-Car tires must not protrude from the body as seen from above
3.-Chassis:
3.1-Kick up or flat chassis allowed.
4.- Engine:
4.1-.21 ci engine (3.5cc) to .28 ci (4.6cc) allowed.
4.2-Engine must be single-cylinder, two stroke,
normally aspirated, air-cooled, with glow plug ignition,
using Standard or Turbo (conical) glow plugs.
4.3-Not allowed forced extraction systems, liquid cooling or carburetor pressurization systems (other
than via the exhaust pressure applied directly to
the tank of the vehicle).
4.4-Any carburetor can be used.
4.5-Except for bearings, the use of ceramic material for
any part of the engine is not allowed.
4.6.-Induction Noise Silencer Box (INS Box) required.
5.- Transmission:
5.1 A maximum of 2 speed transmission may be used.
6.- Electronics not allowed:
6.1-D-Box or Drift Box not allowed.
6.2-Electronic gyroscopes not allowed.
6.3-Active telemetry use during race not allowed.
7.-Brakes:
7.1-Brakes must be on the axis of the transmission.
8.-Differential:
8.1-Standard type of crown and satellites only.
8.2-Central-type differential, Thorsen, TCD and One Way in either are not allowed on either axis.
9.-Clutches:
9.1-Centrifugal clutches using 2, 3, 4, shoes only.
9.2-Coaxial, Push type (Centax) clutches are not allowed.
10. - Fuel Tank:
10.1-Maximum fuel tank capacity including filter and hoses is 150cc.
11. - Muffler Pipe and Manifold:
11.1-A muffler pipe and manifold is required at all times
11.2-Any 2 chamber or more muffler pipe and manifold to .21 or .28 engines will be allowed.
12. -Tires and Rims:
12.1-Only the use of rubber tires and rims that have been manufactured specifically for GT and or Rally Game 1/8 or 1/7 can be used.
12.2-Rubber tires only, both natural and synthetic.
It is expressly forbidden to use foam tires.
12.3-All tires must be black with the exception of
sidewall letters, which can be colored.
12.4-The maximum width of the tire and rim is 45 mm.
12.5-The minimum diameter of the rim is 75mm the maximum is 85mm.
12.6-The minimum diameter of the rim and tire assembly is 85mm the maximum is 110mm.
13. - Fuel:
13.1-Nitro, oil and methanol percentage is open.
13.2-The following additives are strictly prohibited: Hydrazine
(8N2H4), Hydrogen Peroxide, Toluene Propylene Oxide.
CATEGORY GT 1/8 SPORTSMAN:
14.-The GT 1/8 Sportsman Spec Class will follow all General Pro Rules with the following added requirements.
15.- Carburetor Sportsman Spec Class
15.1-Any open engine with a maximum carburetor opening of 7 mm. Restrictor may be used to reduce opening to 7 mm.
15.2-Any engines as found in ready to run cars with functional pull start or roto start can be used without 7 mm carburetor opening restriction.
16.- Driver Eligibility Sportsman Class
16.1-Pro Drivers are not allowed. Pro drivers are defined as drivers that have finished 1st, 2nd or 3rd at any large open GT race or who are fully sponsored.
17.-Spec Tire Sportsman Class
17.1- The race organizer has the option to designate a spec tire.
17.2- The race organizer has the option to designate the number of sets of spec tires that may be used for the race event.
Old 01-14-2014, 09:50 AM   #144
Doug M's Avatar
Default Rules
All the rules are important. The most common cases for disqualification are the following.
Rule 1.1 : minimum weight without fuel is 3500 grams.
Rule 2.8.1 : wing can be no higher than the highest point of the roof line.
Rule 10.1 : maximum fuel tank capacity is 150 cc including fuel line and fuel filter
We will have the tech area open on Friday afternoon for pre tech to check for compliance.
Old 01-14-2014, 09:52 AM   #145
Doug M's Avatar
Default One last rule added.
There is one rule that was left out but is probably the most important rule of all at Homestead RC Raceway.
Please have a good time with all of your fellow racers and have FUN!
Old 01-15-2014, 08:04 AM   #146
Grenade10's Avatar
Trader Rating: 37 (100%+)
Doug for those of us who are not able to make the event, will it be broadcast on the web so we can watch?
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 01-15-2014, 11:01 AM   #147
bassman2's Avatar
Default Video to get your blood pumping!!!
I thought to post a 1/8 GT race video from Lima, Peru in 2012 to get you guys' blood pumping. Battle is ON baby!!!! Oh, also like Doug said, HAVE FUN guys!!!
http://www.youtube.com/watch?v=ZHdIJUphQnY
Record some awesome videos for the 2014 PanAmerica International GT Grand Prix please........Somebody.....pretty please.........
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 01-15-2014, 02:56 PM   #148
Doug M's Avatar
Sorry, no live broadcast to watch. We will try to post results whenever possible on this thread and the Homestead RC Raceway facebook page.
Old 01-15-2014, 11:45 PM   #149
Joseph16's Avatar
I'll have my Go Pro camera with me andy... Are you coming down?
Serpent America & Desoto Racing.
Picco - Arrowmax.
PT RC Racing Oils.
Neal Smith Mods.
Alpha Tires and Body.
Joseph16 is offline   Reply With Quote
Old 01-16-2014, 05:59 AM   #150
howardns's Avatar
is it Friday yet ?
Serpent Cobra GT
howardns is offline   Reply With Quote
