inferno gt2 wider tires >
Old 09-21-2013, 04:16 PM
Default inferno gt2 wider tires
does anybody know a company that makes slicks that are wider for the inferno gt2 im going to start putting mines together and I was some wider rear tires for better traction.....I have the sweep 55 but I want some wider any help out there?
chevyallred is offline
Old 09-21-2013, 04:26 PM
Try the Ipanema wide slicks, you can't go wrong with these.
oskygt is offline
Old 09-21-2013, 04:33 PM
JLock's Avatar
The Ipanema rear slicks are 47mm wide as compared to the 41mm wide that most GT tires are made. I have been running them since they came out and are available in just about all the shores that Ipanema makes (35 shore to 65 shore).
JLock is offline
Old 09-22-2013, 07:29 AM
Try going down a a shore or two, you are running the hardest tire they make. Run a 45 or 40 for the most traction.
TerribleTy is offline
