Old 06-18-2005, 06:12 PM   #1
Jye
Default Car wont roll.
My car hit some type of bumb about a week ago or a little more. The Spur gears were stripped and the engine mounts were knocked loose. That was all of the visable damage and i fixed all of that today. I started my car and it wouldnt move. I hit the gas the engine revved and the exhuast came out and all. I did that for maybe a min to see if something would catch but it didnt. Its like the brakes are engaged at all times. Thanks for any help with this. BTW, i ever took apart my front and rear differntial housing's when i put everything back together and fixed those up so that is not a problem. Had the car since april and now this
Jye is offline   Reply With Quote
Old 06-18-2005, 06:50 PM   #2
onnetz's Avatar
it wouldnt go so you kept revving it?? whatever was wrong wasnt going to fix itself..
anytime you crash or hit a bump, whatever, you should totally disassemble the car to find out what all is damaged. I'm sure that if you do this you find the problem.
onnetz is offline   Reply With Quote
Old 06-18-2005, 08:00 PM   #3
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
New spur gears are on there right. Sounds like they might be too tight. See what can roll and what cant. It should become pretty obvious pretty quickly.
Artificial-I is offline   Reply With Quote
Old 06-18-2005, 08:08 PM   #4
Jye
Red face
i feel so stupid. i changed tires and put them on to tight :/
Old 06-18-2005, 08:58 PM   #5
drfritz's Avatar
put some spacer behind the hex pin and bearing will help on your over tighten problem.
drfritz is offline   Reply With Quote
Old 06-21-2005, 11:47 AM   #6
WeatherB's Avatar
Make sure you didn't toast the clutch shoes when you were revving it for that one minute.
WeatherB is offline   Reply With Quote
G4S roll bar mod - change to mugen roll bar charlesd Nitro On-Road 13 07-01-2008 01:32 AM
revo after foc wont roll back xxx123 Nitro Off-Road 2 09-25-2007 11:56 PM
my car wont go. help please MR. PRO 3 R/C Tech Site Forum 2 04-15-2007 09:52 AM
car wont run littlewhitefw05 Rookie Zone 4 02-22-2007 04:10 AM
Monster GT Roll Cage or Roll Bar complete or Plans? mjm R/C Items: Wanted to Buy 1 03-18-2005 05:12 PM
