Old 08-25-2002, 02:20 PM   #1
Default How to identify Long/Short rod motors?
Hi, I just want to know how I can identify whether a motor has a Long/Short rod? I have a few mt-12's and Nova Mega's and I know that mt-12's are long rods but not too sure about the Mega's. Help would be appreciated
Thanks.
rcpilot is offline   Reply With Quote
Old 08-25-2002, 08:53 PM   #2
NTC3NUT's Avatar
I'm not sure if this is correct but here goes. I have purchased 3 motors this year. The first 2 I know are long rod MT-12's. The 3rd is a new JP RS-12. I think it is probably a new short rod motor. The visual difference from the outside is that on the JP, the piston sleeve is recessed into the block (crankcase). I don't know if that's the reason for it or not, but it sort of makes sense.? The button is also twice as thick to keep the cooling head above the block (crankcase). I tried using a new stock Novarossi button, with a new Kawahara Zac cooling head, and they wouldnt work. When the head was tightened down, the button was still loose. Like I said, that may or may not be a way to tell from the outside.
NTC3NUT is offline   Reply With Quote
Old 08-25-2002, 11:27 PM   #3
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
This may be a bit dumb, but, what is the effective difference between the long and short-rod motors?
I read someone saying that the long-rods are dead. . .?
MT-12 is long-rod? If so, dang, I love mine. . .fastest motor I've had yet. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 08-26-2002, 06:57 AM   #4
dtm
dtm's Avatar
Send a message via ICQ to dtm
Quite simple really...for the short conrods, there is a channel cut into the side of the conrod this is in 2 sections, the long rods has one channel all the way down.
There are quite a few other differences already mentioned like the almost flush sitting cyclinder. Another indication is a 'flat' cut into the back plate...which should be facing upwards when installed on the short rods....
And of course....the short rods are physically shorter!!!
dtm is offline   Reply With Quote
Old 08-26-2002, 07:00 AM   #5
dtm
dtm's Avatar
In the simplest most generic terms;
Short rods- More power at higher revs.
Long rods- More low end torque
This is being very "simplistic"!
Old 08-26-2002, 07:59 AM   #6
Thanks for the info guys.
Long or short ?? nordin Electric Off-Road 6 04-18-2006 01:47 PM
Long versus Short Wishbones SagaMike Electric On-Road 3 03-22-2005 08:56 AM
Long or Short Plug click, dublin Nitro On-Road 0 01-07-2005 05:05 AM
Long arm, short arm, what's different ttso Nitro On-Road 4 11-14-2004 09:04 PM
fs: Two Xray evo 2's (short or long armed) One bmi, etc..... XCrash R/C Items: For Sale/Trade 10 06-10-2004 07:31 PM
