Old 07-21-2013, 04:06 AM   #1
Bundy_Bear's Avatar
Default Cleaning 2 speed one way bearing
Hi
Can you use degreaser or motospray to clean out the one way bearing in the 2 speed before you re-lube it with One Way oil?
Thanks in advance
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 07-21-2013, 04:51 AM   #2
Originally Posted by Bundy_Bear View Post
Hi
Thanks in advance
Andrew
I clean with disc brake cleaner quite sometime already,so far i don't facing any problem.but becareful the one way pin will fly away.
kyosho malaysia is offline   Reply With Quote
Old 07-21-2013, 05:12 AM   #3
Bundy_Bear's Avatar
Thank you
MissMooRC Racing
Old 07-21-2013, 06:13 AM   #4
Very seldom do any cleaning on the one ways ,when it's time to give the rest of the car a bath the two speed doesn't go in the parts washer , if it is necessary to clean the one way the solution is to make a roll of paper towel to loosely fill the center loosely to keep the needles in place while spraying with brake clean , then gently rotate and spray again till you are sure it's.clean , let dry and as you mentioned previously relabel with a few drops of one way lube (which I'm suspicious may be trans fluid of some type ).
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 07-21-2013, 12:37 PM   #5
asw7576's Avatar
Tissue, toilet paper, or clean rags.
I dont want to use sprays ....... i dont want to release harmful gas into our atmosphere.
Btw, don't put too much oil into 2speed bearings ...... the oil will come out from the bearing. 1 drop of oil is enough.
Old 07-21-2013, 03:23 PM   #6
Steve_K's Avatar
My engines release harmful gas into our atmosphere .
Steve_K is offline   Reply With Quote
Old 07-21-2013, 04:27 PM   #7
I use gun oil
Theo49306 is offline   Reply With Quote
Old 07-21-2013, 08:56 PM   #8
Its probably not the best oil to use but I use the Mystic 3in1 oil. I use it as after run too. I did have a problem once, but that's because I put to much oil into the one way, and it slipped. Used a Q-Tip to soak up as much oil as possible, and then it was fine. Now I use about 1 drop every 2-3 weeks (about 2 hours of running) on the one way, and everything works fine.
Shawn.
Shawn68z is offline   Reply With Quote
Old 07-22-2013, 12:09 AM   #9
Geezatec's Avatar
Most one-way brgs 2Sp or Frt axle work better when clean and dry. One-way oil or grease attract dirt and grime as usual. Cleaning in alchohol and keep it dry. Lubing will need maintainence more often. Its up to you. One-way to me are cheap. IMO.
Geezatec is offline   Reply With Quote
