Old 05-29-2005, 01:52 PM   #1
dct147's Avatar
Default Keep hitting brakes
Hi guys,
Hae got a new problem.
Hope i can seek some help.
I`ll have to be a little long winded on this one as i don`t know the terms.
ok, here goes... i`m running a shaft driven car. and i`m having problems with the plastic attachment which is connectted to the front servo that turns the wheels. i hope i`m clear. whenever i turn left, the servo pulls back and cause the plactic piece to hit my brakes. i`ve tried using a thinner plastic piece , but it still hits my brakes. i can`t lessen my angle of turning as it wouldn`t be enough. any advice pls?
Thanks alot!
Cheers!
dct147 is offline   Reply With Quote
Old 05-29-2005, 02:00 PM   #2
Jye
What car do you have?
Jye is offline   Reply With Quote
Old 05-29-2005, 02:05 PM   #3
dct147's Avatar
Running a FW05T
Old 05-30-2005, 06:19 PM   #4
dct147's Avatar
any idea anyone?
Old 05-30-2005, 06:31 PM   #5
What did you change? Didn't you change a servo? With the stock servo mine is about 5/6mm away from the rotor when the wheels are at full left turn. The servo can pull the linkage a little more but it still doesn't hit the rotor
3434 is offline   Reply With Quote
Old 05-30-2005, 09:35 PM   #6
By the way you are describing it you might want to check your servo end point adjustment. Hope this helps.
Jamie Corrado is offline   Reply With Quote
Old 05-30-2005, 10:02 PM   #7
rcabj's Avatar
do u have ay pics to show the problem...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-31-2005, 05:51 AM   #8
dct147's Avatar
thanks for all your replies. i can`t get my pic up as the file`s too big. might wanna try editing the size.
but meant time, i have changed my servo once.from my stock perfex to a futaba 3003. i can only tune my end point adjustments from my controller. and tuning it to the max would mean hitting on my brakes. to the point where it doesn`t hit on my brakes, would mean too little steering.
It`s hard to describe the plactic piece i`m talking about. it`s the one which connects my servo to the point where it turns the wheels.
my servo`s working fine.
Old 05-31-2005, 06:02 AM   #9
I know exactly what you are talking about, I have the same car. Your talking about the servo horn hitting the rotor. Did you use the horn that came with the car or one that came with the servo? If you used the one that came with the servo it might be a different length.
Old 05-31-2005, 10:42 AM   #10
This what you are talking about?
Old 05-31-2005, 11:34 AM   #11
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Be sure your using the correct servo horn. There should be a few sets in the kit. Choose the one that goes to your servo and you should be fine.
Also be sure to check your steering linkage length. It could be too long or too short causing it too pull so far back to get yourself the turn you need. Making sure this is set correctly, how the instructions say....then it should be good.
Artificial-I is offline   Reply With Quote
Old 06-01-2005, 11:05 AM   #12
dct147's Avatar
Once again, Thanks to all.
Servo horn`s not stock.
Probably that`s the problem.
Will try that out once i`ve time.
Thanks to all u guys.
Cheers!
Xray hitting the smaller venues... Gitsum Colorado Racing 2 05-28-2008 10:59 PM
Got my B4 hitting a top speed in the mid 40s mig rod Racing Forum 2 03-15-2008 03:16 PM
Savage dual brakes hitting clutchbell....HELP!! billyp1106 Nitro Off-Road 0 01-15-2008 01:29 PM
Top Driving Styles: Using Brakes and Drag Brakes SlamMan Electric On-Road 32 04-30-2007 11:11 PM
Blade CX blades hitting each other?? Dan RC Flight 12 09-13-2006 02:58 PM
