Old 05-28-2005, 11:50 AM   #1
Dragon's Avatar
Send a message via ICQ to Dragon
Default Kyosho V-ONE S III
Harlow all.... new convert to nitro here... hehe
I just got myself a V-one S III as a start... and just finished building it... yay!
However, cant start playing yet cos they didnt give enough silicon tubing...Im just 1cm short of it... dunno why...
Anyone else here got one too?
Dragon is offline   Reply With Quote
Old 05-28-2005, 11:59 AM   #2
Chaya's Avatar
hey dragon,
I just own a v1s2. can you compare the two. What are the new spec of V1s3 compared wit the s2, maybe you can send some pix here tnx
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
Old 05-28-2005, 12:30 PM   #3
Dragon's Avatar
Updated Pics
Kyosho V-ONE S III-dvc00168.jpg   Kyosho V-ONE S III-dvc00171.jpg   Kyosho V-ONE S III-dvc00173.jpg   Kyosho V-ONE S III-dvc00135.jpg   Kyosho V-ONE S III-dvc00139.jpg
Old 05-28-2005, 12:38 PM   #4
Dragon's Avatar
Differences between the II and the III?
i dun know much about the II, but from what i read was that the III has:
-New servo layout (flat down now)
-2 Speed
-Better engine GXR15 w. new kind of pull start
-Filter cover
-No handle to carry the car (or it could be i cant find it)
-Somekind of so called lightweight front spool diff (crap if u ask me think i will change to a better one)
Old 05-28-2005, 05:11 PM   #5
Chaya's Avatar
The S3 is much of the same as RRR. Based from the review ive read from the kyosho site, the design was inspired ( almost the same ) with the triple R. You just have to change the upper deck to look the same as the RRR. . .
And from your pix, it is totally different from the S2. . . . from the orientation of the laydpown servo. and the new location of the battery & reciever ( side by side) from the fuel tank. ( fuel tank now is located in the middle). .Im not sure if it has the same 2 speed tranny with the RRR. but the gear ratio as as written is identical to RRR 8.13/5.6:1. One thing I observed was the new design of chassis ( same as Fwo5).
By the way Mr. Dragon. what is the thichness of the chassis? 3mm or 4mm??
thanks for sharing the pix. . .how much is the price of your kit
Old 05-28-2005, 08:23 PM   #6
Dragon's Avatar
Hmm not sure if u can just change the deck like that.... the middle so called deck is a ONE piece kind of thing... the 2 servos, batt, receiver and tank are all intergrated together.
After conversion it should be around USD 330. (hope i didnt get chopped)
lower deck seems like 2.5/3.0mm or even between to 2 (gotta lousy ruler )
Btw know anywhere i can find a kyosho parts list? preferably wif pictures, cos the kyosho main site dont seem to show the full parts list...
Old 05-28-2005, 09:02 PM   #7
What happened to your manual? Kyosho usually has a pretty good layout of the car in there with all the part #'s. From your pictures the 2speed gears look like they are from a madforce or GP20.
3434 is offline   Reply With Quote
Old 05-28-2005, 09:12 PM   #8
Dragon's Avatar
I do have the manual, but its rather confusing... it says:
OPTIONAL PARTS 2:
use these parts to install a front diff:
-beval shaft
-diff gear set
-pulley set (rrr)
-Diff Pulley set (rrr)
-Diff joint (19)
Does this mean i have to get ALL these parts to make just 1 front diff set? And the brackets (rrr) do they mean its originally ment for the V-one RRR?
and if those numbers by the side mean YEN...
578+945+630+945+630=3728=USD 33.56=SGD56.44 (is this about right?)
Old 05-28-2005, 09:55 PM   #9
Yes you will need those parts, it should have the part #'s too. You are probably right about the prices in YEN, but those are list prices so you should be able to do better. Kyosho did the same thing with the RR/EVO. It didn't come with a front diff so you had to buy all the parts. Later they offered a complete kit that was cheeper. I would like to see that manual, I'm sure it will be on Kyoshos site soon.
Old 05-29-2005, 06:47 AM   #10
Chaya's Avatar
If the manual didnt mention anything regarding brackets on your option parts, then definitely the V1s3 brackets and the V1r3 brkts are the same. . .
Old 05-29-2005, 07:33 AM   #11
bulletdays's Avatar
Default Dragon
Hi Sir,
the bracket (rrr) signifies that you can use the diff gear of RRR, they can share these parts, actually i have a Vone SII, and i remove the TCD gear and transfered it into my RRR..so i think u can use it without any prob.
Most of the Vone series can share parts...
You can try RC Champ, or RC Mushroom for parts..
hope this helps..
bulletdays is offline   Reply With Quote
Old 05-29-2005, 07:35 AM   #12
bulletdays's Avatar
Default Vone SIII Improves
The concept of Vone SIII is more likely similar to RRR, it combines both Vone SII & RRR structure..so it should be a great car, easy to setup and gives more speed than the SII..
Old 05-29-2005, 08:46 PM   #13
Default Where to Buy
Hey dragon,
Did you buy ur kit in singapore? where in singapore and how much? thanks!
prgervacio is offline   Reply With Quote
Old 05-29-2005, 11:45 PM   #14
Dragon's Avatar
Thanks for the info guys...
Originally Posted by prgervacio
Hey dragon,
Got it from toykar orchard branch...
Old 06-02-2005, 06:04 AM   #15
Dragon's Avatar
Got my body done... cant bare to use it thou...
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
