Old 06-21-2005, 03:06 AM   #46
Dragon's Avatar
Send a message via ICQ to Dragon
Umm, sway bars are anti roll bars right? I was thinking of installing those, but i cant seem to find anywhere on the arms to install them.... is it possible to show a blown up pic of it?
Dragon is offline   Reply With Quote
Old 06-21-2005, 03:59 PM   #47
Yes. The sway bars mount the little tabs sticking up at either end of the rear arms. You need pillow balls and linkages to install them though. They do not bolt straight on. If you cannot find sway bars anywhere on the net try; www.rcmart.com
Hope this helps.
BS
KYOSHORACER is offline   Reply With Quote
Old 06-21-2005, 04:16 PM   #48
Take a look at the exploded view or manual to the RRR WCE (you can download it off Kyoshos site). That should give you a pretty good idea how they go on.
3434 is offline   Reply With Quote
Old 06-21-2005, 09:00 PM   #49
Default SERVO SAVER
Don't know if you had this problem however when I did up the top screw that holds the servo saver shaft in place it was binding under that top plate. I ended up using some locktight on it and not screwing it down completly. I now have a fraction of play if I slide the server-saver up/down on the shaft. I was disapointed that the server-saver used bushes instead og bearings.
Bad Inferno is offline   Reply With Quote
Old 06-21-2005, 10:10 PM   #50
Hello I have V one SII but the engine is not that good and I replace a O.S. engine But my smartech that I bought a year ago still running
Bryanmag is offline   Reply With Quote
Old 06-21-2005, 10:15 PM   #51
hello chaya we still can get any parts of V one SII?
Old 06-21-2005, 10:26 PM   #52
Hello chaya how much did you bought your V one SII in manila
Old 06-21-2005, 10:34 PM   #53
Hey Chaya still your GSI 5-R engine in your V one SII?
Old 06-21-2005, 11:10 PM   #54
Dragon's Avatar
Nope, dont have that problem... yup quite sad they didnt use bearings there, and other certain places which i forgot where too...
Old 06-21-2005, 11:34 PM   #55
Tim Johnson's Avatar
Just incase you are having trouble finding parts for your Kyosho here is a link to a map of Shops that carry Kyosho parts. This map is updated every two weeks give or take. CLICK HERE FOR THE MAP
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 06-22-2005, 12:36 AM   #56
Chaya's Avatar
definitely, our lhs here in manila still has the parts for my V1s2. In case if our lhs dont have the part, she order the requested part from japan directly.
Price is: 11,000 php( 200US$), original price from lhs is 13500php (245us$). But i bought my V!s2 from a friend which has a contact from japan. Thats why my kit was originally electric start. However, electric start is only good for several months. the internal gear of my quick starter broke. So i already replaced this with a pull start. . .
yap!!! my s2 still uses GS15R. but I have already done several modification. such as usage of UM210 clutch shoe, change pinion gear to 18/20 combination. modification of exhaust pipe & manifold. and lastly i have converted it lay down servo
by the way where you from????
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
Old 06-22-2005, 12:44 AM   #57
Chaya's Avatar
Originally posted by mr Bad inferno
Hi Chaya,
The stock chassis is 3mm however the side edges have been folded up 30 degrees. This would give it great strength.
Hey thnx for the info.
It (30deg fold) would definitely give your chassis an extra strength. . . chassis of my s2 was bended when i accidentally hit a post during practice I just fixed it with a hammer. hehehe
Have you already raced your s3. . .how does it perform compared from your s2????
Old 06-22-2005, 01:42 AM   #58
got any pics of your sII with the lay down servos. (interesting).
Cheers
BS
Old 06-22-2005, 01:51 AM   #59
Chaya's Avatar
Ill try to post it within this week. try to find any digital camera here i just got the idea from the S2 thread. page 135. i forgot the name. if you want i can send the original pix where i copied it from... just hope they wont sue me for copying ( hehehe).
Old 06-22-2005, 02:14 AM   #60
that would be great thanks
BS
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
