Old 08-16-2002, 04:40 PM   #1
Default Using 5 port piston sleeve on MT12/XT12 (long con rod variants) ok?
Hi All ,
The Nova MT12/XT12 is a long con rod design as we all know. And the new 5 port sleeves are used on RS12/RB X12 designs.
Questions are.
1. Is it possible to fit a long con rod on a 5 port piston and sleeve set? has anyone tried this?
2. Are there performance gains from putting a 5 port nova sleeve in a JPMT12? Will it be reliable?
JP parts are very hard to come by locally. Just toying with ideas. I have seen enough discussions in Motorman's forum to think that this may be possible. Please help. Thanks.
Hammer0412 is offline   Reply With Quote
Old 08-16-2002, 05:29 PM   #2
rod_b's Avatar
Send a message via AIM to rod_b
Well, first off I would think that running a long conrod with a sleeve timed for a short conrod would make the engine not run very well. As for 5-port sleeves in 3-port cases, I don't know for a fact whether this would or wouldn't work. I've been told that the cases for 5-port engines are different to accomodate the additional ports. I guess only someone who's opened up all these engines would be able to tell you. Anyway, good luck in your findings
rod_b is offline   Reply With Quote
Old 08-16-2002, 07:27 PM   #3
You raised very good points...but you're right....only someone who's very familiar with the internal workings of engines would be able to answer this matter of factly.
I guess a lot of people with older 3 port engines can stand to gain from knowing this.
If it works, we wouldn't have to buy a new engine to be more competitive...
thanks rod_b!!!
Old 08-16-2002, 07:31 PM   #4
sparksy's Avatar
Trader Rating: 14 (94%+)
I seriously dont see a sleve designed for a short rod working in a long rod engine... the ports would be in all the wrong places..
sparksy is offline   Reply With Quote
Old 08-16-2002, 09:12 PM   #5
dtm
dtm's Avatar
Send a message via ICQ to dtm
It works ok...I have an RB 5 port in an MT case, obviously you have to change the conrods. I measured up all the heights of the ports and they do match. The piston also bottoms out at the same point. As for performance? I can't really compare because I like the higher torque of the 3 ports so this is the only 5 port I have. Low end torque is down but mid-high end is pretty good, which is what I expect from a 5 port anyway.
dtm is offline   Reply With Quote
Old 08-16-2002, 10:13 PM   #6
sparksy's Avatar
Well, I stand corrected.
Old 08-18-2002, 10:46 AM   #7
Racmark's Avatar
Anyone tried converting a 3 port turbo to a 5 port turbo? I understand that for the RB X12 the diferences are only in the sleeve and crankshaft.
Racmark is offline   Reply With Quote
Old 08-18-2002, 04:46 PM   #8
AMGRacer's Avatar
The new novarossi 5 port block has an air splitter in the transfer ports cast into the case. I am not sure whether the 3 port has this. Apart from that the sleeve is identical in its dimensions. The 5 port crank is different and illegal as well.
AMGRacer is offline   Reply With Quote
Old 08-18-2002, 08:15 PM   #9
Motorman's Avatar
Yes everything swaps, just use the right rod with the right case and its all good. In a long rod case the liner sits on top of the case in a short rod case it sits almost flush when its installed. Piston and liners are common with 2 exception. I will give you the important one for RE engines. You must use the piston and liner assy with the skirted or cut out area on the bottom of the piston on a short rod engine or it will hit the crank at the bottom of the stroke. You can use a short rod style piston and liner on any long rod nova RE engine. Rods are common as are cranks. Crank timing at the crank is the same between them all. All cranks and bearings interchange. All novarossi cranks are legal as are JP style cranks. All meet Ifmar and ROAR rulesets
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 08-18-2002, 09:29 PM   #10
InitialD's Avatar
Dennis, by saying Nova / Novarossi, can I take it that you also include NovaMega variants? Does RB also include in this category?
Are NovaMega engines short rod or long rod type? What about RB ones? Thanks
Old 08-19-2002, 01:23 AM   #11
Wow! A lot of people are very helpful here...but I didn't expect Dennis himself to answer my question...I actually wanted to post this directly to you...but after reading the Motorman forum I was a bit shy to do so.
Thanks so much for the input everyone! Thanks Dennis!
Old 08-19-2002, 04:05 AM   #12
Motorman's Avatar
No problem.
Nova megas have been short and long rodded, RB's have always been short rods. Mugens are long rods, but are going short rod. Side ports are generally long rods. Yes they fall into novarossi variants.
There have been misconceptions with regards to cranks and these have even been listed in print all over the web that there are long and short STROKE varieties of nova 12 engines. This is simply NOT TRUE. The stroke on them is all the same just the rods are short and long.
The Base timings have not changed at the CRANK windows either, at least not at the crank itself. HOWEVER the short rod engines have about 8 degrees more intake duration that is induced by the shorter rod, this is caused by increased crank angle change over a shorter travel path of the piston in relation to the boost and transfer path openings on the liner. This gives the engine more top end. This is why you will see crank timing changes advertised at times on some sites. THIS is actually true even though the base crank has not changed. This is also why Race engines I have built in the past for people do not have interchangable cranks. My long rod cranks wont swap into a short rod case and run properly because the crank timing will be screwed up. My short rod cranks will swap into the long rod case though and run fine.
However in the case of stock ones they are a direct plug in and go.
Old 08-19-2002, 05:34 AM   #13
No problem.
Just wondering people...why did they have to shift from long rod designs to short? Is it because of the bigger demand in the States and Europe for high RPM engines due to the larger track sizes?
First they spent years with the long rod design starting off with the side exhaust novas and all its variants...
Then they actually spend money to change their production process to accomodate a different con rod design by making it shorter...
Now they have a new Novarossi MR12 (Mugen engine) which is actually seen as a compromise between the two designs...as a sort of best of both worlds thing...
What gives?
Old 08-20-2002, 08:38 PM   #14
InitialD's Avatar
No problem.
Thanks for this valuable info, Dennis It is always interesting to be able to learn new things about the subject that interest you, especially myself coming from a mechanical engineering background.
Anyway, you mentioned about how to differentiate short roded and long roded engines by the piston liners flushed or not flushed fully. How do you mean that it is not flushed fully? My Mega 12RET's liner is slightly not fully flushed to the crank case. Is this a long rod varient? What models of the Megas that are short rodded?
Second question, the 5 port version of the Mega is already out. Have you heard anything about it yet? (MS tuned and non MS tuned). Some feedbacks mentioned that they are going to be better than the Novarossi S5 because they have a different carb. The MS version also has a different crank.
Thirdly, after a days running, should the top of the piston be black in colour or should it be sparkling clean with no deposits on it? I'm using Byron's 25% with Novarossi plug no. 7. Total shims is 0.6 mm (0.3 + 0.3 = 0.6 mm). Ambient temperature is 90 to 100 F with a high humidy of over 90%. Altitude is sea level.
Sorry for being long winded with many questions. Thanks again
F/S 5 port gotech and a extra 5 port piston and sleeve cheesecake R/C Items: For Sale/Trade 5 07-01-2008 09:44 AM
WTB MT12 Piston Sleeve DWill_996 R/C Items: Wanted to Buy 1 05-02-2006 12:28 PM
Piston/Sleeve for mt12 magna_matt R/C Items: Wanted to Buy 5 04-16-2005 08:16 PM
Where to get MT12 piston/sleeve? boom Nitro On-Road 3 08-26-2002 09:36 AM
Where to by MT12 Piston and Sleeve? AZ_Ron Nitro On-Road 7 03-28-2002 05:43 AM
