Old 05-31-2013, 08:17 PM   #1
Trader Rating: 3 (80%+)
Default No movement from idle screw, carb slides out
I've got a nitro rs4 from HPI. Been trying to adjust idle screw, but no matter how I turn or nothing happens.mthe only difference is if I tighten it all the way the throttle doesn't work.
Any ideas? Also had another thread on this with getting it to idle and run properly, the only thing that changes the idle speed is playing with the HSN. Moving the LSN does nothing at the moment. And with it not being able to idle I can't run it to tune.
FYI the radio and transmitter is on when I play with the idle screw, but the car isn't running
icey05 is offline   Reply With Quote
Old 05-31-2013, 11:05 PM   #2
blis's Avatar
Does the throttle close when you brake?
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 05-31-2013, 11:54 PM   #3
Yes sir yes it does
Also when I tighten the screw, the throttle doesn't move at all even with the servo
Old 06-01-2013, 12:42 AM   #4
blis's Avatar
Yes sir yes it does
Check radio trim, loosen throttle and brake servo push rods, put a rubber band between carby slide and top needle to keep it shut. Remove air filter, ensure idle gap close (tweak idle screw back to factory) and align your throttle and trims, tighten. Turn radio on and look to carby without air filter and set your endpoints if applicable.
Old 06-01-2013, 12:46 AM   #5
Problem is idle screw doesn't change anything. When I tighten it, throttle won't move at all. Loosening it doesn't change idle gap
Unless your saying by putting rubber band to stop carb slide sliding out will help the idle gap?
Old 06-01-2013, 12:48 AM   #6
Also my throttl is different from other rc kits I've seen, the throttle is a ball joint set up, no springs or anything
Old 06-01-2013, 07:38 AM   #7
djiewie's Avatar
pictures
djiewie is offline   Reply With Quote
