Old 05-31-2013, 02:36 AM   #1
Trader Rating: 3 (80%+)
Default Nitro rc won't start - its brand new never run
Got a new HPI rs4 with a G3.0 engine. Have had it start a few times but idles high, then low and cuts out in a couple of seconds.
I've got a firestorm which has basically the same engine but didn't have as many problems. Only difference is that my igniter was on its last legs but it still started but as said died
Could this just be a 'new engine needs to run' thing. Or does it seem like the carb needles need a change from base settings.
icey05 is offline   Reply With Quote
Old 05-31-2013, 06:12 AM   #2
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Break in
Richen up the bottomend first about a half a turn, then richen up top about quarter turn,also you may have to bring the idle up some because the motor will be running alittle rich, this should help when you are breaking the motor in, what percent nitro fuel are you using an how hot is the plug you are using?
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
