Old 09-30-2001, 06:52 PM   #1
pusher's Avatar
Default Hpi C-12
Anyone know what the base line carb settings are for this motor ?
Thanx.....
Jim
RIP Final Thoughts Club
M and J Charters......C and R Racing
Red Cup Racing (Cooler Weight Reduction Specialist)
Drifting......The Special Olympics of Motorsports
pusher is offline   Reply With Quote
Old 10-07-2001, 10:01 AM   #2
NItRO PuPS's Avatar
Send a message via AIM to NItRO PuPS
This is off Parisracing.com
CX12 .12 engines Slide carb:
High-speed needle: [vertical adjustment] turn in until closed [gently] then open 4 turns.
Low speed needle: [Adjustment in end of slide] turn out until flush with end of slide and linkage attachment then turn in 31/2 turns.
Mid range adjustment: [Brass screw in end of carb body] set flush, normally this is rarely adjusted!
Idle Speed: [small screw that enters side of carb body on angle] turn in until slide is held open .5mm [apx. .020 inch] or thickness of matchbook cover.
Rotary Carb:
Low speed needle: [Adjustment in end of rotating barrel] turn out until flush with end of barrel and linkage attachment then turn in 3 1/2 to 3 3/4 turns.
Mid range adjustment: N/A
Idle Speed: [small screw that enters side of carb body on angle] turn in until barrel is held open .5mm [apx. .020 inch] or thickness of matchbook cover.
there ya go
NItRO PuPS
NItRO PuPS is offline   Reply With Quote
Old 10-07-2001, 06:48 PM   #3
pusher's Avatar
Thanx Pups, yer a lifesaver.
Jim
Old 10-07-2001, 06:50 PM   #4
NItRO PuPS's Avatar
Thumbs up
No prob
NItRO PuPS
Old 10-08-2001, 03:50 AM   #5
Trader Rating: 15 (100%+)
Cool
i see you found a new place to hangout nitro pups
Kyosho Superten FW-04, O.S. 4 stroke conversion, fully optioned, shelf queen... my baby!
nitro dave is offline   Reply With Quote
Old 10-08-2001, 11:42 AM   #6
NItRO PuPS's Avatar
Yup
this place is cool i still gotta get used to it tho hehe
NItRO PuPS
