Old 05-23-2013, 08:15 AM   #1
Default 1/8 Foam tyres characteristics?
Enneti tyres, Xceed tyres,Horace tyres, Contact tyres, ZAC.tyres, and Matrix tyres....
Can anyone tell me about the characteristics of these tyres? Which one is good foe
low/med/high traction track, technical / fast-track.
Thanks!
Capricorn LAB C801/OS ENGINES/FUTABA/FUTABA
victor1997621 is offline   Reply With Quote
Old 05-23-2013, 08:49 AM   #2
~McSmooth~'s Avatar
Thanks!
All those brands will be very similar. I've been told over the years that most tire companies get their rubber from pretty much the same places.
I see in your signature that you run a 1/8 car. From my experience, you're going to run 32 Front and 35 Rear at most tracks.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 05-23-2013, 09:00 AM   #3
wingracer's Avatar
Trader Rating: 24 (100%+)
First thing you need to know, THEY ALL USE THE EXACT SAME FOAM!
Sorry for the shouting but I know people are going to argue with me on this and you need to know it.
Now that we have that out of the way, we can get to the real issues. Even though the foam is all the same, there are some differences between tire brands but it's not because one has better foam than another or some such marketing BS.
Wheel design/flex can make a difference. Most have slightly different offsets from each other so going from one brand to another will change your track width which WILL handle differently if you do not adjust for it.
How the doughnuts are cut can make a bit of difference. Some use a small inner hole, forcing the rubber to be stretched over the wheel more. I don't think it makes much difference but I hear it does make some.
Age of the rubber can make a difference. Rubber that was just made 2 weeks ago, mounted one week ago and slapped on the car today will usually have a bit more grip than stuff that's been sitting in a warehouse for a year. Then again, high bite often likes old tires that have been sitting in a hot car for a year.
Durometers vary. One company's 35 can be anothers 37. Many years ago I was running a very unpopular brand and winning regularly with them. Everyone else that tried them said they sucked but they were all trying the 35s (which were really more like 38s) while I was running 30s and 32s. Also the rears were a different offset so if you just slapped a set on your car, your rear track width would be 4mm narrower.
So ultimately there is no hard and fast rules about what is best. You have two options, try everything until you find something that works for you or pick a brand that's affordable and available and work your set-up to match.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-23-2013, 11:23 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
Fresh tires is a hot issue. If you are not sure about the freshness then Matrix is a good choice because they are airtight sealed.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 05-23-2013, 06:59 PM   #5
Which brand of foam tyres do most people use?
Old 05-23-2013, 08:23 PM   #6
wingracer's Avatar
When it comes to the US, whichever one is most available at the time.
Team Shepherd USA
Old 05-24-2013, 08:17 PM   #7
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Enneti and Matrix seem to be the most popular and you also have Hot Race
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-24-2013, 08:26 PM   #8
I just got Enneti light rim and Matrix Xtreme carbon rim in my hand.
The Matrix xtreme rim is wider than the Enneti tyres for 2mm.
What will this "extra 2mm" gains?
Old 05-24-2013, 08:30 PM   #9
When mounted on the car what side is the extra gain?
Old 05-24-2013, 08:32 PM   #10
choisan's Avatar
I always pre conditioned by spraying wd40 my used tires or those thinner tires after race in a zipped bag for a few days. This process can refresh the tires
choisan is offline   Reply With Quote
Old 05-24-2013, 08:32 PM   #11
Phil Trotta's Avatar
Contact patch. Rear grip.
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 05-24-2013, 08:33 PM   #12
Contact patch. Rear grip. Check the differences in track width
PHIL TROTTA
