12 Volt Starter Box Battery: Help Needed
I've returned to the hobby after being away for a year.
When I tried to charge my 12V battery for my starterbox, it wouldn't charge. The voltage reads under 6V. During the charging phase the amp reads 0.00. Then the charges stops as if the battery has peaked. I know there's nothing wrong my charger, I already charged other batteries with it. Is there anything I can do to save this battery or is it time to buy a new one?
Battery specs:
Tysonic nonspillable rechargeable SLA battery
12 V 7.0 AH
Stand-by Use: 13.5-13.8V voltage regulation,
Initial current: no limit
Cycling Use: 14.4-14.7V voltage regulation,
initial current: 2.1A max
Charger:
Super Brain 969 Pro Series
Starter box:
Ofna 10258 (12V motor)
Battery specs:
12 V 7.0 AH
Charger:
Starter box:
It's quite possible that the cells have dried up. We get the same problem with these batteries in emergency lighting if they go long periods without being charged.
put a fork in it, it's done, history, put it too rest and by a new one.
This one's done. Going to get a new one ASAP!
Did some surfing, found some info. Great informative article on lead-acid batteries.
http://www.rcbatteryclinic.com/
Try charging it with your car battery charger. You won't be able to charge that with any regular rc charger. You could with a turbo 30 or 35 with a power supply over 15 volts, but not with anything less. Even if in an add it says so.
How long were you gone? It probably is gone if the charge ran out of it and it was left like that. But never know.
I pick up a new battery yesterday. Different brand name but essentially the same specs. I had a salesperson check the voltage before I made the purchase. It read about 12.84V or 12.86V.
At home I hooked it up to my charger. I charged it at 0.5 amps with a peak setting of 5mV. It charged for less than 5 minutes, then the charger beeped signifying a peak charge. I checked the voltage. 12.96V. That link to the battery site states a full charge at 13.00V.
Just to make sure it wasnt a false peak, I tried to charge it again at 0.5 amps. Within a few seconds the amp output would gradually fall 0.5, 0.46, 0.31... until it reached zero. I stopped the charge immediately, and repeated the process once more with the same results.
One thing that confuses me is during those last 2 attemepts of trying to charge the NEW battery, the charger displayed the same readings as when I was trying to charge the old battery.
1. The charger's work capacity read 100.
2. The Amp output would start at the set rate, then gradually fall to zero output within a few seconds.
So my understanding is:
1.The charger didnt want to charge the OLD battery cuz it was beyond revival.
2.The charger didnt want to charge the NEW battery cuz its already fully charged. I installed the battery into the starterbox already... its works, but I havent tested the capacity yet... going to be breaking in a new .21 engine sometime this week.
3. My charger could be malfunctioning. Bad timing as I know its past warranty.
4. My charger doesnt like to charge lead-acid batteries anymore...dont know why... it used to in the past... it could be possessed. It clearly states on the box and in the instruction manual that this charger will charge LEAD-ACID batteries... was the reason I bought this charger in the first place.
Yep, I been away for a good year. the old battery was left to sit that long.
SO I can charge the old battery using a real car-battery charger.
It wont blow up?
Long post... to much coffee this morn.
It wont blow up?
You can-not charge a 12 volt battery even the little starterbox batteries with your rc charger. It just won't do it. Doesn't matter if the charger manual states it will, it won't. What are you using for a power supply? If it isn't 15 volts or so you won't be able to charge that 12 volt battery with it. Try your car battery charger. That's what I use even on new starterbox batts.
The MRC Superbrain 969 is supplied with a DC power supply which attaches to the charger.
DC Power Supply:
INPUT: 120-240 VAC, 50/60 Hz
OUTPUT: 13.5 VDC, 5 Amp
I'll check my real car battery charger to see if it can charge at 2 Amps. OR what Amps should I charge at. Does the C10 rule apply?
I have a Triton and I've been charging my 12 volt startbox battery for the longest. It might not be the best way to charge a 12 volt pb lead acid battery but its working for me sofar. No complaints.
2amp on the car charger works great. This is the only way I have charged by battery. I would have not even thought to have used my RC battery charger. Just not made for this battery type.
I'll give the real car-battery charger a try. I have a Sears 4-in-1 charger which has a 1.5amp mode for charging motorcycle bats. It also has a 0.35amp maintenance mode.
The charger has a timer function.
How long do I charge it for?
Do I stop the charge when the battery reaches a certain voltage?
Any tips on charging is greatly appreciated.
Thanks bro, you've been a great help, much appreciated.
