Old 05-09-2005, 08:48 PM   #1
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Default Chunked 10th scale tires (SAVE THEM)
How many do you have? I've started repairing them and came up with a glue that leaves no hard seam where repaired. anybody else doing this? If anybody has any, don't through them away, look into the items wanted.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 05-09-2005, 08:52 PM   #2
performula's Avatar
Well share the fun!
performula is offline   Reply With Quote
Old 05-12-2005, 04:36 AM   #3
nsxshogun's Avatar
Send a message via AIM to nsxshogun
What type of glue???
nsxshogun is offline   Reply With Quote
Old 05-12-2005, 06:50 AM   #4
Vince's Avatar
i used to glue them with a thin layer of goop. it would dry up to be hard but forgiving. i use my chunked and repaired tires for practice
Wallace Motorsports
WRC
Murnan Modified Motors
VP Fuel
Hot Race Tires
Vince is offline   Reply With Quote
Old 05-12-2005, 09:46 AM   #5
teammpp's Avatar
Evostick brown glue is the best. Wont part but wears along with the foam.
teammpp is offline   Reply With Quote
Old 05-12-2005, 05:11 PM   #6
tranced's Avatar
it might help to let us in on your "secret".. telling this to us then asking us for our chunked tires is a bit selfish
tranced is offline   Reply With Quote
Old 05-15-2005, 03:19 PM   #7
The best solution that I have found is a good quality contact cement ... it stays flexible and wears well with the foam.
duckman996 is offline   Reply With Quote
Old 05-15-2005, 08:15 PM   #8
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Shoe Goo!!!!!!!!!! Top notch.
Tire Chunker is offline   Reply With Quote
Old 05-16-2005, 03:07 AM   #9
rcfoolz's Avatar
I'm using a mixture of Latex rubber and M.E.K. mostly
Old 05-16-2005, 06:00 AM   #10
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I use the trashcan on them, then I proceed to bust out the credit card and I renew them to perfection. Within seconds. Easiest method so far IMO.
Not but seriously. They have an article on this on subject of the rcnitro or rccaraction sites..... I would see what they use.
Artificial-I is offline   Reply With Quote
Old 05-16-2005, 10:17 PM   #11
R/C Tech Charter Subscriber
Ahright when you are ready to breakout the credit card try www.twistertires.com. Sweet Deals.
CA Glue works just fine also.
racinghobbies is offline   Reply With Quote
Old 05-17-2005, 08:33 PM   #12
I am a little confused. Are you talking about replacing the chunked section with the chunk from the same tyre found on the track or are you talking about using a piece cut from another tyre and fitted into the missing section?
rcosmax is offline   Reply With Quote
Old 05-18-2005, 03:25 AM   #13
teammpp's Avatar
We have done both. They make good practise tires.
Old 05-23-2005, 07:04 AM   #14
rcfoolz's Avatar
they make excellent practice tires and I have used them for club racing too. Also I have been using 1/8th scale tires and soaking them in laquer thinner and they slide off the rim and after they dry, I put them on 10th scale rims. It doesn't take long, and it saves some money for just running around parking lots or breaking in engines or whatever.
1/10th scale bsr cap tires ohiorcracer R/C Items: For Sale/Trade 3 08-24-2008 10:53 AM
fix bent rims & chunked tires rcfoolz Nitro On-Road 6 12-26-2005 09:01 PM
Is there a way to fix chunked tires ? charlesd Nitro On-Road 3 07-31-2005 03:43 AM
Chunked Foam Touring Tires! rcfoolz R/C Items: Wanted to Buy 0 05-09-2005 08:54 PM
1/10th scale tires on 1/8th scale rims Jon Carlson Electric Off-Road 6 08-19-2004 09:32 PM
