Old 03-30-2013, 06:10 PM   #1
Lt819's Avatar
Default 2 Speed tranny Un-Adjusting
I have an RS4 3, and just installed a 2 speed tranny on it. It works well For about 4-5 tanks of fuel then it doesn't Shift anymore i end up having to make the shift points shorter so it shifts again. there's 2 springs you get with the 2 speed tranny, A black and a silver one, the black one is supposed to be for higher performance engines and Vice Versa for the silver one, I have a T 3.0 so i figured I would use the black one?
Any tips on how to fix this issue? or if you think maybe i should just install the silver spring?
Thanks,
Matt
Lt819 is offline   Reply With Quote
Old 03-30-2013, 07:52 PM   #2
Trader Rating: 24 (100%+)
Thanks,
Matt
sounds like the engine got alittle rich. lean the top just alittle then try it if it still will not shift then lean alittle more till it dose
RANDY SMOOTH is offline   Reply With Quote
Old 03-30-2013, 07:55 PM   #3
the t3.0 isnt really a high performance engine, may want to try the silver spring.
Sharkey_t is offline   Reply With Quote
Old 04-25-2013, 08:42 PM   #4
Lt819's Avatar
Default :)
ya, silver spring did the trick thanks.
