Old 09-29-2001, 02:24 PM   #1
Default yokomo GT-4 clutch
HI everybody
Quick question? Iam puyying my car togeater and I cant figure out how the heck am I supposed to tightin the clutch nut on to the crank shaft? It seems like there is no space left? Iam useing the RB concepts X12 motor. Any help would be greatly apprecated.
madmacs is offline   Reply With Quote
Old 09-30-2001, 04:55 PM   #2
Snake_bit's Avatar
I dont Know What You are Talking about for Sure but if the Flywheel Keeps Spinning When You Try To tighten it You Will Need a Piston Locking Tool Of some Kind I belive traxxes makes 1
Also You Can Hydra-Lock the Piston too With After run oil. Personally I use a Traxxes Type locking tool And I know People Will Say it puts Stress On the Piston and Rod But If you Stuff Is that Weak you Need to replace it anyway. I have used this tool a Million times with No problems this is the Duratraxx tool Hope this Helps.
http://www2.towerhobbies.com/cgi-bin...1&I=LXD567&P=7
Snake_bit is offline   Reply With Quote
Old 09-30-2001, 07:09 PM   #3
Thanks Snake
My problem is that it seems the threds on the crank shaft are a little bit off. Iam thinking I'll have to somehow push the flywheel down to get clutch nut to hit the crank shafts threads. Oh thanks for the link. I dont have a problem with it spinning. That will be on the list of things to get .
thanks
Old 09-30-2001, 07:16 PM   #4
Snake_bit's Avatar
Meaning the threads are Cut Short? If so You Might Be able to Use a Differant Style Clutch Nut That might help if you can get 1 to match your Clutch Bell.
Old 10-01-2001, 07:20 PM   #5
Yes thats what iam thinking snake. I think it may be a Yok thing or I am really stupid and dont really know what Iam doing. You whould think when you buy the kit with a "super" motor everything would fit. Iam just going call Yokomo tomarrow and see what they say. Right now I get to find a lost e-clip that went flying. Hey does anybody know if the GT-4 kit has a few extas clips?
Old 10-01-2001, 08:35 PM   #6
Manticore's Avatar
R/C Tech Charter Subscriber
It seems you dont have the right collet. You should get a thinner collet so that your flywheel can sit lower/closer to the engine.
Manticore is offline   Reply With Quote
Old 10-01-2001, 11:43 PM   #7
Regional Moderator
disaster999's Avatar
humm...talking about clutches, i was wondering, engines shouldnt vibrate that much right? i hold one of my friends car before and notice that it didnt vibrate that much! not as much as mine!! i was wondering if the clutch is unbalanced, would this make the car twice as much! im using the OFNA Centex clutch with lots of balls.....
disaster999 is offline   Reply With Quote
Old 10-03-2001, 06:29 PM   #8
Hey Manacore that sounds like the problem. Would it work if I shave the top down a bit? I really that would work but i didnt really want to start shaveing stuff when I dont have to yet its my understanding you have to you get to do that with Yok kits.
Thanks for the tip
Old 10-03-2001, 06:37 PM   #9
Manticore's Avatar
Thanks for the tip
the kit should have come together with the right collet. I think you can get one from yokomo but I am not quite sure about it.
Old 10-03-2001, 08:53 PM   #10
Your right manacore. The kit should be right yet I think I wil shave the booger down ans see what happens. I may even talk to Yok some day.
thanks again
Old 10-06-2001, 11:47 PM   #11
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Lightbulb
What crank do you have? SG or standard?
They both need different type of collets. Just make sure you didn't lose one.
Dan is offline   Reply With Quote
Old 10-09-2001, 06:48 PM   #12
Hey Dan the shaft is standard. The other collet wont even make it down to the threads on the crankshaft. I'll just have to breakdown and call Yok and see what they say.
thanks guys
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 01:34 PM
FS: NTC3 yokomo centax clutch: new-in-package rossiRocket R/C Items: For Sale/Trade 3 11-23-2004 08:04 AM
WTB: Yokomo GT4 Centax clutch CheckkYaaSelff R/C Items: Wanted to Buy 0 08-10-2004 01:24 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 09:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
