Old 05-03-2005, 12:58 PM   #1
factory racer's Avatar
Default internal cleaning????
after i take out the piston sleeve con rod and crank shaft (basically take apart the motor) wat do u guys reccomend i use to clean the parts???????? is WD40 good to use?????? or use after run oil............
factory racer is offline   Reply With Quote
Old 05-03-2005, 03:45 PM   #2
anyone have any imput?
Old 05-03-2005, 03:55 PM   #3
teammpp's Avatar
Default Re: internal cleaning????
After run oil is fine for week to week racing. For longer periods of sit up I like ot strip the motors and let them lay in a tray of oil (like castrol, mobil 1, etc).
teammpp is offline   Reply With Quote
Old 05-03-2005, 05:36 PM   #4
no...i always used after run oil i no that but i mean over the winter or even over a day lets say i want to clean the internals of my motor (piston sleeve con rod crank shaft) what would i use to clean it all up.......would WD40 do the job or anything else anyone has had luck with??????????
Old 05-03-2005, 07:46 PM   #5
nitrodude's Avatar
I like to take mine apart every couple of months. What I do is, I wipe all the engine parts with a clean rag. Once I have the bare case(with or without bearings) I clean the whole case with a water based degreaser (simple green works) and a tooth brush. Once its nice and clean I rinse it and soak it with WD-40, I use a lot on the bearings to displace any water left on them. After the WD-40 I let it sit overnight and then I put it together with some ARO. I also reaseal everything
I HATE!! the look of a dirty engin.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-04-2005, 09:48 PM   #6
straightsixers's Avatar
With my engine, after i've removed all the individual parts blast nitro cleaner on all the items i.e. piston, sleeve, case, c/shaft, etc to remove any dirt. After that it's WD40 and a clean rag to rub off any remaining hard to rid dirt. Next is polishing with autosol with a rag (make sure not to leave any of this stuff behind. polish it thoroughly except the piston and inner walls of the sleeve). Then its a generous dash of after run oil on all parts and bearing oil on the engine bearings before assembling them together. I do this as often as i can after every race. If you want your engine to last you should make time and effort in maintaining it.
straightsixers is offline   Reply With Quote
Old 05-05-2005, 02:59 AM   #7
teammpp's Avatar
Yeah. For longer breaks like winter etc I let everything lay in oil (Mobile 1, Castrol, etc).
Old 05-05-2005, 08:55 AM   #8
trashcar's Avatar
Default cleaning
For excellent removal of any debris boil the parts and allow to soak in heated ethylene based antifreeze,do not use silica base.
trashcar is offline   Reply With Quote
Old 05-05-2005, 08:57 AM   #9
trashcar's Avatar
Default cleaning
PS a lot of phosphate base strong detergent cleansers (high alkili) will discolor aluminum
Internal Ratio Jamesalex Electric On-Road 2 08-04-2008 04:38 PM
Internal Ratio's implusepro Nitro On-Road 4 12-07-2007 03:41 AM
Internal resistance The_Gaz Electric On-Road 13 05-05-2004 10:08 AM
TC Internal Ratio Kenneth Tan Electric On-Road 23 12-13-2003 02:41 AM
Internal Ratio Cripp Electric On-Road 4 05-31-2003 07:42 PM
