Old 08-06-2002, 03:55 PM   #1
Send a message via ICQ to QALA R/C TEAM
Exclamation 15ld-x probleam
HI i am from malta and i have a leaking problem on my 15ld-x o.s engine its leaking oil from the #E-1000 silencer what can i do
QALA R/C TEAM is offline   Reply With Quote
Old 08-08-2002, 07:33 AM   #2
VONEREFLEXR's Avatar
Where at in the silencer is it leaking.
VONEREFLEXR is offline   Reply With Quote
Old 08-08-2002, 01:08 PM   #3
Default 15ld-x
between the silencer and the crankcase besause the silencer is fitted directely to the crankcase and when id drive it i allways find some oil on the chassis
Old 08-08-2002, 01:17 PM   #4
do you have a gasket in between there, if not you will need one, if you do it might be a bad gasket
Old 08-08-2002, 01:34 PM   #5
boner's Avatar
Or you can use Ultra copper gasket sealant. I found it work better than paper/fabric type gasket.
boner is offline   Reply With Quote
Old 08-08-2002, 02:00 PM   #6
Actually that stuff does work better
Old 08-08-2002, 02:42 PM   #7
boner's Avatar
QALA R/C TEAM:
Which car is powered by your Powerblock? I have a 12LD on my FW04, I love it.
Old 08-08-2002, 02:47 PM   #8
I also had a 12ld on my superten, sounds Similiar to an F1 engine
Old 08-09-2002, 04:23 PM   #9
Default 15LD-X
I fitted the 15ld-x to the tamiya it is very fast and it gives me a good performance . But only that problem that i have of leaking oil
Old 08-14-2002, 04:57 AM   #10
Default boner
can i up grade my 15LD-X??
Old 08-14-2002, 08:35 AM   #11
boner's Avatar
QALA R/C TEAM:
What are kind of upgrade are you looking forward to do? MSpeed is the only company I know that are making aftermark parts for OS Powerblocks. http://www.mspeed-jp.com
Old 08-15-2002, 09:43 AM   #12
Default boner
sorry man but i can't read japanes
How to Upgraded my 15LD-X QALA R/C TEAM Nitro On-Road 1 08-19-2002 01:38 PM
