Old 02-20-2013, 03:52 PM   #31
Originally Posted by JLock View Post
If I run open, I will try to hit that mark. The last couple of times racing there, I had a bunch of 11 lap runs and I think that I had a couple of 12 lap runs (at least one for sure). And that was with the wrong diff oils in my car!! I think I have that issue resolved and should be ready to keep up with you guys when I get there in May. I am definitely running the Spec class for sure and still on the fence for electric GT.
Let me ask, what kind of lap times/number of laps are the electric GT turning on the track in a qualifier on average? What kind of diff oils are some of you using in your electric GT cars (front/middle/rear)? If I bring mine, I want to be somewhere in the ballpark and tweak it from there.
I use 400K up front and 40K rear. If you run diff in the middle use 400K. I don't know what the others use. Well I was runnig the wrong car but did run some 12 laps and did 11/5.00 with front wheel drive only (damn locktite didn't work). So doing 13 as well is not out of the question. I bet in this race we can see more racers get into the 14 laps.
jneg is offline   Reply With Quote
Old 02-21-2013, 08:30 AM   #32
JLock's Avatar
Thanks for the helpful/useful information jneg. Got one more question for you, "Will my 2050Kv motor be enough to keep up with the group?" I will get to work on my diffs and try to have the car ready in case I do decide to bring it.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 02-21-2013, 09:13 AM   #33
C@T's Avatar
As long as the rules are not published your question will have to wait for an answer.
If 6s will be allowed it should be ok. With 4s only you will be at the low side.
C@T is offline   Reply With Quote
Old 02-21-2013, 10:32 AM   #34
JLock's Avatar
jneg,
These were the rules established for electric GT last year (from the Ipanema website):
GT Electric Open:
1. Chassis: Any 325mm to 360mm wheel base Shaft-Driven buggy/truggy off-road GT chassis and GT conversion is permitted.
2. Body: Any commercially available “GT” racecar style/type body, must look like a car that could actually be driven on the street with a passenger in real life or 1:1. Rear wing and/or spoiler/flap must be attached to the actual body. (No chassis mounted or “Buggy/Truggy” type wing mounts)
3. Tires: Only commercially available Rubber tires. Tires must fit under car’s body from over-head view. Adding “fender-flairs” on body to increase tire coverage is not allowed. (Foam tires are not permitted) Liquid traction additives orrubber enhancment chemicals are not permitted.
4. Batteries: Any type of commercially available Hard-Case units are permitted. Batteries must be removed from chassis to be charged or peaked in a "charging bags" for racer/track safety.
Just need some clarification on the battery rule as far as what are the limit(s) of what can be used.
Texas 5
Old 02-21-2013, 03:12 PM   #35
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
What kind of tires are you guys using?
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 02-21-2013, 06:26 PM   #36
jlock most here use those KV in their motors. Mine is a 2250KV. The rules for open electric will be almost the same and here are the rules:
GT Electric Open:
3. Tires: Only commercially available Rubber tires. Tires must fit under car’s body from over-head view. Adding “fender-flairs” on body to increase tire coverage is not allowed. (Foam tires are not permitted) Liquid traction additives or rubber enhancment chemicals are not permitted.
4. Batteries: Any type of commercially available Hard-Case 4S units are permitted. Batteries must be removed from chassis to be charged or peaked in a "charging bags" for racer/track safety.
Old 02-21-2013, 06:28 PM   #37
We allow any rubber tires that are available, some here use Ipanema, Alpha, Sweep, etc. All are welcomed.
Old 02-21-2013, 06:43 PM   #38
GT Electric Open:
Why the 4S limit? 6S is actually more effcient and should result in less stress on the speedo/motor.
desotoracing is offline   Reply With Quote
Old 02-22-2013, 01:17 AM   #39
C@T's Avatar
What is the desiered duration of the heats in qaualification and finals for the brushless cars ?
Old 02-22-2013, 07:35 AM   #40
JLock's Avatar
GT Electric Open:
jneg,
Thanks for the clarification/update of the electric GT rules. Just need to get another 4S pack and redo the diffs on my car and I will be good to go.
Texas 5
Old 02-24-2013, 07:15 PM   #41
Hi, when the nitro rules are going to be published?
Desoto Racing--Serpent --Novarossi
Serpent Cobra B w Novarossi Plus 4
Serpent Cobra T TE w/Novarossi Roma Team
Serpent Cobra B 2.0 w/ Novarossi Keep off XLS Team
Serpent Cobra GT w/Novarossi P5XL
agtuning is offline   Reply With Quote
Old 03-12-2013, 12:05 PM   #42
JLock's Avatar
72 days and counting.....................
Texas 5
Old 03-12-2013, 01:56 PM   #43
JLock's Avatar
Here is the link to the Ipanema GT World Championships webpage:
http://www.gtworldchampionships.com/Pages/default.aspx
Here is a link to the rules for all the classes for the upcoming race in May:
http://www.gtworldchampionships.com/...12GTRules.aspx
Texas 5
Old 03-12-2013, 07:38 PM   #44
scary_jerry's Avatar
Smile
Just to clarify the 'Spec Class Engine Rule' for me , is that supposed to mean .....the 'Werks B2 and the OS...' are THE only engines for that class????
Thanks..
scary_jerry is offline   Reply With Quote
Old 03-13-2013, 07:59 AM   #45
Thanks JLock for the link, I've had many problems with internet connection.
