Old 02-11-2013, 11:05 AM   #1
Default engine mounts
i am about to order a LRP .30 motor for my GT1 ,currently the stock .28 sits directly on the chassis, i know i have to order engine mounts but there is a plate that has to be ordered that goes between the chassis and the mount , i have seen several and some said 3mm left & right , there are also some on ebay thats a 1 piece unit meaning the mount and spacer are together, not sure which to get thnx
jamdude is offline   Reply With Quote
Old 02-12-2013, 03:55 PM   #2
utah300rum's Avatar
Trader Rating: 27 (100%+)
The ones I have seen on ebay are still a 2 piece mount just the pic shows them screwed together. I dont know how well they are built, I have had mixed results with cheap aluminum parts off ebay, some have been great others the aluminum was way too soft and screws tended to strip out easily.
I use the Kyosho "SP" upgraded mounts with the stock plates...it is pricey but I got my set used for $10.....the ones off ebay look tempting at less than 1/2 the price of the SP mount alone.
Here are some links
stock engine mount
http://www.infernosonly.com/KYOIF108.../kyoif108b.htm
upgraded SP engine mount
http://www.infernosonly.com/Kyosho_H.../kyoifw102.htm
motor plates
http://www.infernosonly.com/KYOIF210...p/kyoif210.htm
Spooky's Racing for Asphalt & Carpet, Blacksheep Raceway for off-road, Utah Mountains for bashing!
utah300rum is offline   Reply With Quote
Old 02-13-2013, 08:57 AM   #3
thanks for the info i just ordered the mounts and spacers
Old 02-13-2013, 09:00 AM   #4
hey just to be sure, the stock motor plates are 3mm?
