Old 04-21-2005, 08:19 PM   #1
Default converting 200mm
can you convert a 200mm into a 235mm?what would i need?and does it matter on the type of car?if it is not posable to convert it into a full scale 235mm what is the next best thing to get it to 235mm?
better than you is offline   Reply With Quote
Old 04-21-2005, 08:56 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: converting 200mm
you can so the serpent impulse all you need is the impact wheels axles and dogbones i did mine a few years back and it cost me less than $100!!
Old 04-21-2005, 09:04 PM   #3
does it matter if i have a ntc3
Old 04-21-2005, 09:11 PM   #4
Super Moderator
Marcos.J's Avatar
im not sure about that one!
Old 04-21-2005, 11:30 PM   #5
AndyT ©'s Avatar
The dog bones and arms may not be available to do it with a NTC3....try a post in the NTC3 forum and perhaps someone there knows if its possible.
Cheers
AndyT © is offline   Reply With Quote
Old 04-22-2005, 10:30 AM   #6
Trader Rating: 16 (100%+)
235mm is the width of the car.............in order to get to that wide, the WIDER rear tires and axle is the KEYS.
For NTC3.............froget about it, no such thing can convert NTC3 to 235mm unless you can machine all the special parts.
Buy a used Impact/835 with 15 enigne for less then $250 on ebay in any day and night now....they are dirt cheap.
Old 04-22-2005, 02:07 PM   #7
nsxshogun's Avatar
Send a message via AIM to nsxshogun
go to wolfpackradacals.com and get some of the axels and it might work.
nsxshogun is offline   Reply With Quote
Old 04-22-2005, 02:23 PM   #8
trashcar's Avatar
Default tc3
TC3 diffs won't live, don't waste your time and money.
trashcar is offline   Reply With Quote
Converting to Pro Kit Chevron89 Nitro Off-Road 9 07-12-2007 10:36 PM
Converting 4WD To 2WD Toolbox™ Electric On-Road 7 01-28-2007 07:29 AM
Converting an XR 80 to the XR8 llamont Nitro On-Road 16 09-06-2006 07:05 PM
Converting a BK2 to a XXX-CR pvtysux Electric Off-Road 31 07-27-2006 07:20 PM
converting TC3 to TC4 AEDave Electric On-Road 2 11-10-2005 01:50 AM
