Old 09-03-2013, 09:02 PM   #151
Default Adapters
Here are pix of the adapters I made to be able to use the current wheel/tire set-up. As I mentioned the non-diff side is not a problem but the diff side requires some thought!
For the design we are discussing now, I think I should be able to make something similar to what you describe. I think I can make it externally adjustable, but time will tell.
Spec 1/8 Pan Car .21 no frill's racing-img_20130903_215730_009.jpg
Spec 1/8 Pan Car .21 no frill's racing-img_20130903_215758_376.jpg
Spec 1/8 Pan Car .21 no frill's racing-img_20130903_215912_310.jpg
aarcobra is offline   Reply With Quote
Old 09-04-2013, 05:47 AM   #152
howardcano's Avatar
Trader Rating: 35 (100%+)
These are absolutely beautiful! On the live (non-diff-side) adapter, does the axle go most of the way inside the wheel for strength, or does it stop somewhere within the large-diameter section?
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 09-04-2013, 05:54 AM   #153
howardcano's Avatar
Default Brake Disk Hex Drive
I just realized that the clamping wheel hubs used for 1/10 Touring Cars would work nicely as a brake disk hex drive. They fit a 5mm shaft (which is what I will use for the jackshaft), and are very cheap! The only proviso is that the brake disk must have a 12mm hex, or be easily modified to it (fiber disks should be pretty easy to change).
Does anyone have some suggestions for brake disks that might work with a 12mm hex drive?
EDIT: Here are the possibilities I've found so far for the disk:
Duratrax Nitro Evader ST: Tower says the hex is 12mm, but the disk is fiberglass (not a great material!).
Associated RC10GT: Nice fiber disk, but what is the hex size?
Associated Monster GT: Ditto.
Associated GT2: Not a hex, but could be modified.
Duratrax Street Force GP: Looks like fiberglass, hex size unknown.
Traxxas T-Maxx: Hex looks too big, but don't know for sure.
Howard Cano
Old 09-04-2013, 11:32 AM   #154
Default Adapters
Thanks. I think they will work but the diff adapter has a thin section that may not take a big hit. I 'm too lazy to make scale drawings so I wing it!
The live side can be any depth, the Associated axles I'm using are very short so it's not inside the wheel. The adapter I showed you is a two piece experiment to cut down on machining. The hole in the wheel is .472" dia. so a 1/2" piece of stock with a collar to hold the wheel is what you see. The parts can be one for more strength by using a larger diameter or as you say longer axle.
Old 09-04-2013, 11:38 AM   #155
Default Hexes
Associated Brake Disk GT2: Not a hex, but could be modified.
Just a caution on the axle hole in the hexes: They are not all straight, one diameter holes. Many of the ones I have are stepped. THey would work but would need to be drilled to a constant diameter.
The hex on the Associated disk I have is ~.437" No sure what vintage!
Old 09-05-2013, 07:39 AM   #156
howardcano's Avatar
Thanks for the heads up. I'll try to source the non-stepped variety.
Howard Cano
Old 09-06-2013, 04:29 PM   #157
Taylorm's Avatar
.Hey Ned...what about a drum brake?...but not on the clutch bell..put an extra hub on the axle..super simple and cheap...
http://i227.photobucket.com/albums/d...ps05538b4c.jpg
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 09-07-2013, 05:36 AM   #158
howardcano's Avatar
The drum can't go on the axle if we use a ball diff. That would give one-wheel braking.
Howard Cano
Old 09-07-2013, 07:32 AM   #159
NutDriver's Avatar
Trader Rating: 19 (100%+)
It CAN go on the jackshaft, though.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 09-07-2013, 09:20 AM   #160
howardcano's Avatar
Yup, I think most of us agree that's the best place for it.
Howard Cano
Old 09-11-2013, 08:49 AM   #161
howardcano's Avatar
Default Front End Ideas
Does anyone have some ideas or photos to share for the front end? Suggested arms, knuckles, etc?
Howard Cano
Old 09-11-2013, 09:29 AM   #162
NutDriver's Avatar
I haven't talked to Ned in a few days, but he had a bean axle that he had fabbed and I believe that he had fabbed the knuckles as well. Pretty basic stuff. We discussed using the pros and cons of using square or round stock. Not sure which direction he preferred. Sorry I couldn't be more specific, Howard. I'm sure Ned will be back online soon.
USVTA member #111
Old 09-11-2013, 09:40 AM   #163
howardcano's Avatar
The beam axle looks simple enough, but the weight concerns me. I'm also concerned about kingpin strength, since most beam setups don't support the top of the kingpin, although I suppose that could be included. (I'm currently planning on using 4mm or 3/16" kingpins and axles.)
It would be nice to use existing knuckles (and suspension arms, for that matter), but I haven't found anything that seems suitable. Failing that, I was planning on making knuckles from 3/8" square 6061.
Howard Cano
Old 09-11-2013, 11:04 AM   #164
ScottE1776's Avatar
Default front end pictures
Here are a few pictures of the R&A front end for the RC100-200 with kingpin support.
Spec 1/8 Pan Car .21 no frill's racing-rc200_1.jpg   Spec 1/8 Pan Car .21 no frill's racing-rc200front1.jpg   Spec 1/8 Pan Car .21 no frill's racing-rc200front2.jpg
ScottE1776 is offline   Reply With Quote
Old 09-11-2013, 11:55 AM   #165
howardcano's Avatar
Thanks for the photos, Scott!
I don't have the capability to machine the whole thing shown, but it should be possible to do something very similar with two long flat pieces separated by spacers.
The method of attaching the steering arms in the second photo is neat, as it is done at a 90 degree orientation away from what I was considering (I'd guess to save hardware).
Do you have any idea why the first photo has the center section of the beam removed? It looks important to have it for impact strength.
Howard Cano
