Old 04-18-2005, 03:53 PM   #1
WeatherB's Avatar
Default Throttle Return Springs: Who uses them?
Hey guys,
I made a throttle return spring out of a rear exhaust spring and noticed that it causes the engine / chassis to flex slightly. I cannot use anything with less strength since then it won't close the throttle.
Is this okay or should I find a way to fix this? Also, is there any "real" need for a throttle return spring?
WeatherB is offline   Reply With Quote
Old 04-18-2005, 10:25 PM   #2
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Default the fix
Use a good quality coreless throttle servo and a light spring to do the job. You will answer your own question of the linkage falls off the carb. Nothing like WFO into the outside wall. I have had some trouble with some digital servos for throttle. I still prefer analogs for this job.
Slapmaster6000 is offline   Reply With Quote
Old 04-18-2005, 10:39 PM   #3
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Be sure you are cutting power. It wont return with power still on of course.
Artificial-I is offline   Reply With Quote
Old 04-18-2005, 10:58 PM   #4
WeatherB's Avatar
lol, naturally.
Old 04-19-2005, 03:21 AM   #5
adamkerrnz's Avatar
thats the idea of them
adamkerrnz is offline   Reply With Quote
Old 04-19-2005, 03:56 AM   #6
Julius's Avatar
Default Re: Throttle Return Springs: Who uses them?
Originally posted by WeatherB
Hey guys,
Attach the spring to the carb in stead of the car itself. Then you won't flex the chassis.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-19-2005, 07:39 AM   #7
WeatherB's Avatar
Thanks, I'll give that a try...
Old 04-19-2005, 07:48 AM   #8
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Re: Throttle Return Springs: Who uses them?
like this!!
1/8 scale throttle return - What do you use? largeorangefont Nitro Off-Road 1 05-18-2008 10:05 PM
Throttle return spring 4 8ight-T with Axial Tony899 Electric Off-Road 4 04-08-2007 05:12 PM
Team Losi Throttle Return Spring for LST Cain R/C Items: Wanted to Buy 2 10-28-2005 11:02 AM
NTC3 nitro throttle return spring ideas for slide carb motors? calstarjig90j Nitro On-Road 5 09-13-2004 10:56 PM
Radio throttle/steering return springs ChrisP Electric On-Road 7 04-12-2004 08:30 AM
