Old 01-17-2013, 12:51 AM   #1
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Default Camber link length
I'm trying to understand the difference the camberlink length will make on the handeling of the car. There are two mounting position for the link on my car, inside and outside. I know changing the length changes camber, but im refering to the mounting position on the chassis
I know that shortening the link will give you more camber rise, but how does it effect the handeling of the car. will it give you more/less traction?
At what stage will it effect the handling, corner entry or exit?
What type of track would you change the length to a longer/shorter length?
ProE is offline   Reply With Quote
Old 01-17-2013, 02:27 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
It will have an effect on the roll center and simply translated the roll of the car with the roll center settings and camber rise you are determing how the tire will grip with the surface. Actually the same question was recently in the offroad section:
http://www.rctech.net/forum/nitro-of...-handling.html
With usefull links.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-17-2013, 01:23 PM   #3
ProE's Avatar
THanks Roelof. That info helped a lot.
Tune With Camber Links Sarinexia Electric Off-Road 2161 11-18-2017 07:45 PM
The "OFFICIAL" Camber Link/Roll Center Debate Thread Cptn Cartwheel Electric Off-Road 102 10-21-2016 12:37 AM
Which is more important? Upper link length, or roll center crazyjr Electric Off-Road 6 09-21-2007 02:59 PM
Setting: Droop VS Camber link position Alvin Electric On-Road 55 01-13-2002 10:21 PM
