Old 04-14-2005, 11:26 AM   #1
revzalot's Avatar
Default Neo Attack 235mm Road Car
Anyone have one? Know where I can get spare parts and tires? Can I use Impact/835 parts for it?
revzalot is offline   Reply With Quote
Old 04-14-2005, 11:31 AM   #2
nitrodude's Avatar
You can use the complete drivetrain on it. I should know, I have a heavy moded Neo 1/8th and it uses a lot of parts from the Vector. I dont know about the suspension, but they do look very much the same. I can use upper arms from the Vector, dont know about lower arms though.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-14-2005, 11:38 AM   #3
JLock's Avatar
Cross reference the Impact parts with yours. I have the Maddog 235mm and the Impact parts are identical to the Maddog 235mm. Many of my parts that have been replaced are Serpent. The only problem you may has is that the steering blocks may not be an exact match (bearing sizes may differ slightly). Hope this helps.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 04-14-2005, 11:41 AM   #4
revzalot's Avatar
Are all 235 wheels universal like sedan wheels?
Old 04-14-2005, 12:35 PM   #5
Default neo attack
no. the wheels are unique. the have 1/8 size axles but 235 outer dia.
sedanaddict is offline   Reply With Quote
Old 04-14-2005, 12:43 PM   #6
revzalot's Avatar
I mean are all 235 type wheels compatible with all the 235 cars?
Old 04-14-2005, 01:54 PM   #7
JLock's Avatar
Most pretty much are compatible. The only brand I think might gave you an issue are the ones branded from Mugen. You might want to check others on that issue.
Texas 5
Old 04-14-2005, 02:01 PM   #8
teammpp's Avatar
I believe Serpent, STS and Neo are universal. Dont think the Mugen or other brands can fit on other cars though.
teammpp is offline   Reply With Quote
Old 04-14-2005, 02:06 PM   #9
revzalot's Avatar
Thanks. I have a buddy that has a Mugen Avance and I'm itching to open a can of whoop @$$.
Old 04-14-2005, 02:28 PM   #10
JFCJ's Avatar
Trader Rating: 31 (100%+)
Default 235mm wheels
I just picked up a Mugen Avance, and ready to whoop up on some Neo backmarkers.... lol.. anyway, I found Picco 1/10 Integra mounted tires on Ebay. I've heard the rears will fit the Mugen Avance, but couldn't confirm on the fronts... Has anyone used the Piccos on the Avance?
Q2. Anyone know what arbor for the Avance wheels fits Cobra Tire Lathe?
J
* www.tsrcar.com * John's BSR Racing Tires * Serpent America * BOCA Bearings *
JFCJ is offline   Reply With Quote
Old 04-14-2005, 05:31 PM   #11
revzalot's Avatar
Default Re: 235mm wheels
J
Check out acehardwarehobbies.com for avance tires. Just curious where'd you find the avance?
Old 04-14-2005, 06:48 PM   #12
JFCJ's Avatar
Thanks Rev,
I found it on ebay... my lhs is stocking all of the critical parts since there's acouple of us are running them... being my first yr with nitro, I'm looking to learn alot from the fast guys... and hopefully stay outta the way...
J
Old 04-14-2005, 07:15 PM   #13
revzalot's Avatar
Thanks Rev,
J
I think I was bidding on that. You will like the Avance. My buddy finally got it dialed in and the car runs on rails.
Old 04-14-2005, 07:35 PM   #14
JFCJ's Avatar
The Avance I picked up was brand new with engine needing to be broken in.... there was a roller that ended the past day or so... I bid on it too.. but more than I wanted to go...
Old 04-14-2005, 09:36 PM   #15
soc123_au's Avatar
R/C Tech Charter Subscriber
Picco Integra fronts fit on my 835. The rears will go on with a little modification. So if Serpent ones fit a Neo it is a safe bet the integra fronts will work.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
F/S Serpent Impact 835 235mm 1/10 M2 on Road car 4wd ChuckWick357 R/C Items: For Sale/Trade 2 02-09-2009 06:56 AM
Hudy Set-up System for 1/10 On-Road Cars (10mm axle) 235mm $19.99 Tire Chunker R/C Items: For Sale/Trade 2 05-03-2007 08:10 AM
Hudy Set-up system for 1/10 on-road cars (with 10mm wheelaxle) 235mm Tire Chunker R/C Items: For Sale/Trade 2 12-01-2006 07:46 PM
Neo attack UNKNOWN_MEMBER Nitro On-Road 4 01-15-2003 02:29 AM
