Old 05-14-2005, 04:20 AM   #91
teammpp's Avatar
Originally posted by revzalot
What other options parts were there for the Attack?
I still have the distributors price list. I'll have a look and see what option parts were available. I know there were loads of them.
teammpp is offline   Reply With Quote
Old 05-30-2005, 09:43 PM   #92
sunny's Avatar
Originally Posted by nitrodude
IMO, thats just a aluminum chassis that has been anodized black. Look at the lettering in the engine mount area.
that chassis is an optional part made in carbon material. not aluminium then anodized black.
sunny is offline   Reply With Quote
Old 05-31-2005, 12:37 AM   #93
nitrodude's Avatar
You cant anodize carbon fiber.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-31-2005, 06:46 AM   #94
trashcar's Avatar
Default Chassis
He SAID it's NOT anodized black.
trashcar is offline   Reply With Quote
Old 05-31-2005, 06:50 AM   #95
trashcar's Avatar
Default Chassis
Looks like the old serpent graphite chassis,they had engine heat problems as the graphite was not a very efficient heat sink.
Old 05-31-2005, 01:36 PM   #96
nitrodude's Avatar
OOPS!! I still think its aluminum though.
Steven Muller
Ronin Speed Parts
Old 05-31-2005, 02:10 PM   #97
Default Optional Parts List
Part Number Description
OP-02 Center Force Clutch Complete Kit 1/8
OP-03 Bearing Adapter
OP-04 Graphite Radio Tray 1/10
OP-05 Graphite Radio Tray 1/8
OP-06 Hollow Mid-Shaft
OP-07 Bearing 12x18mm
OP-08 Alum M Screw M3.5x12
OP-09 Alum T Screw M3.5x12
OP-10 Alum T Screw M4x10
OP-11 Alum M Screw M4x12
OP-12 Alum M Screw M3x10
OP-13 Alum M Screw M3x12
OP-14 Alum T Screw M3x12
OP-15 Alum T Screw M3x15
OP-16 Alum Mid Shaft Mount with bearings
OP-17 Alum Break Braket
OP-18 7075S Alum Chassis 1/10
OP-19 7075S Alum Chassis 1/8
OP-20 Adjustable Ball Differential 1/10 (rear)
OP-21 Adjustable Ball Differential 1/8 (rear)
OP-22 Front Upper Arm Pole
OP-23 Adjustable Alum Anti-Roll Bar Kit Rear
OP-24 7075S Steering Tie-Rod Kit 1/10
OP-25 7075S Steering Tie-Rod Kit 1/8
OP-26-14F Front Spring 1.4mm
OP-26-15F Front Spring 1.5mm
OP-26-16F Front Spring 1.6mm
OP-26-17F Front Spring 1.7mm
OP-27-14F Rear Spring 1.4mm
OP-27-15F Rear Spring 1.5mm
OP-27-16F Rear Spring 1.6mm
OP-27-17F Rear Spring 1.7mm
OP-28 7075 Alum Screw-FHB 3mmx12mm
OP-29 Adj Centrifugal Shoe Set
OP-36 Hi Perf Clutch Shoe
OP-48 Alum Sway Bar Mount Front
SP-31 Shock Pistion
SP-36 Shock Space for O-Ring
This is as large as my list got. I don't have all of these parts, but I have a few. I am sure there will be questions about several of these, so please feel free to post your question.
About the chassis under discussion. Please see parts OP-18 and OP-04. It is a graphite radio tray and an aluminum chassis. I have these parts in one of my Attack cars and the chassis is aluminum anodized black. It looks identical to the picture that was posted a couple pages back.
davidl is offline   Reply With Quote
Old 06-01-2005, 12:30 AM   #98
sunny's Avatar
well, i've sent 1 set of the special kit with carbon chassis to someone from this thread. maybe he'll share his thoughts when he receive it in the coming week.
Neo Attack 235mm Road Car-neo-attack-mx-4-007.jpg   Neo Attack 235mm Road Car-neo-attack-mx-4-003.jpg
Old 06-01-2005, 06:28 AM   #99
trashcar's Avatar
Looks graphite to me .Numbers do not appear to match what David posted,maybe limited edition?
Old 06-01-2005, 10:08 AM   #100
i had one of these chassis many yrs back. it's carbon made.and trust me guys, it's looks very cool. but i'm not sure whether is it limited edition.
knight is offline   Reply With Quote
Old 06-01-2005, 10:19 AM   #101
revzalot's Avatar
I will let you guys know the verdict on this issue.
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 06-01-2005, 11:24 PM   #102
nitrodude's Avatar
Would the chanfer on that hole be shiny if it was carbon fiber? No.
Steven Muller
Ronin Speed Parts
Old 06-02-2005, 05:59 AM   #103
trashcar's Avatar
Insert for brake pivot ,yes. Would the machined rails and holes be shiny,yes.
I really don't care as the car is obsolete however it looks graphite.
Old 06-02-2005, 10:10 AM   #104
My gratious, it appears people are getting annal.
The parts I had match the parts shown in the pictures. The chassis plate is black anodized aluminum and has the same numbers on the bottom mentioned above. Those numbers do not match the P/N on the Optional Parts List, but I can assure you that it is OP-18. Now the rest of the parts in the pictures are the front and rear bearing blocks, the rear radio tray mount and the radio tray. The radio tray is the graphite upper deck that is OP-04. So all of those parts are in the photos. It is easy to see the graphite piece, radio tray, and think that the entire thing is woven graphite. In reality, it is only the radio tray on top of the sub-assembly that includes the black anodized aluminum chassis.
Additionally, NEO was noted for doing some one-off parts that sometimes were radical. I think it is possible that they actually made a graphite chassis that could have been the same as OP-18. However, I never had one and CRC never identified that one was available. I do have a one-off 1/8 scale chassis plate that was different than the standard chassis and the OP-19 chassis offered as an optional part. It was aluminum with a clear anodized coating. The difference was that it was very thick and had machined recess areas for mounting the equipment. This actual chassis was run by David Chester and Chris Tossolini in past nats and the Texas Biggie. I was told there were only 4 of these in existance.
Old 06-02-2005, 10:56 AM   #105
wenyi...'s Avatar
much debate on the graphite chassis. i do remember that such a chassis was a very limited production during the days. i do not have one but seen a few which left me rather unbelievable. even many drivers can't believe what they see at that time.only the few lucky guys have it..................how envious i was man......too bad,it was too limited....
wenyi... is offline   Reply With Quote
F/S Serpent Impact 835 235mm 1/10 M2 on Road car 4wd ChuckWick357 R/C Items: For Sale/Trade 2 02-09-2009 06:56 AM
Hudy Set-up System for 1/10 On-Road Cars (10mm axle) 235mm $19.99 Tire Chunker R/C Items: For Sale/Trade 2 05-03-2007 08:10 AM
Hudy Set-up system for 1/10 on-road cars (with 10mm wheelaxle) 235mm Tire Chunker R/C Items: For Sale/Trade 2 12-01-2006 07:46 PM
Neo attack UNKNOWN_MEMBER Nitro On-Road 4 01-15-2003 02:29 AM
