Old 01-04-2013, 05:25 AM   #1
BBQboy's Avatar
Default Servos for 1/10th on-road
Just want to query about Servos for 1/10th on-road as im lookin for High voltage sanwa. One for the steering and throttle.
My querys are:
- Is speed affected by the rate of angle that the servo produces for example
(7.4v servo can produce 0.06 @ 60 degree) if this is correct
is 40 degree faster than 60 degree?
- And is the amount of torque produced from a steering servo can suit varying types of tracks with low to high levels of traction. For example ( 20kg steering servo would be great at high traction track but is not good a low traction track)
Because I myself have not put decent servos in car. As i have come to realise at our last nationals that I was suffering insufficent grip and i couldnt find out why. Till the end of the meet is came down to servos.
Walter RC Hobby. Team picco Australia
Serpent 747 | Podified race fuel | Utli-rc | Zac Project |Picco | Reds Racing
Western Sydney Race Centre
ARC R10 | Orca | Ride
BBQboy is offline   Reply With Quote
Old 01-04-2013, 06:25 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
No, the torque of a servo has nothing to do with the grip. The speed of the servo can be a factor, slow servo's need to be activated before the corner so the steer on time. Once I had driven slow servo's too and I could make good fast laps, going to faster servo's I noticed it was much easier to place the car at any line of the track.
My advise of the specs of the servo's are at least:
- 8kg force
- 0.1 sec speed @ 60 degrees
- metal gear.
60 degrees is a larger distance than 40 degrees so 60 is faster.
I also noticed a transmitter with a high framerate like the Futaba HRS systems and the DX3R with higher framerates does do something as well in the reaction time.
You can calculate some things. The slowest reaction:
speed servo + framerate + latency (delay time)
With the older Spektrum DX3 set and a standard servo:
140ms + 20ms + 11ms - 171ms
With a fast framerate a fast servo and the latest latency
60ms + 5ms + 3ms = 68ms
You think the framerate and latency is not much but with the 20mS difference a 0.08 sec servo on a good transmitter can be as fast as a 0.06 sec servo at a bad transmitter
Again, faster servo's will give a directer steer but it will not change the grip.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-04-2013, 02:39 PM   #3
BBQboy's Avatar
- 8kg force
- metal gear.
Thanks for your help Roelof but what im trying to say that in high conditions a steering servo that has low torque specs cannot hold the load
Old 01-04-2013, 04:19 PM   #4
Roelof's Avatar
Be aware that digital servo's can create more force to hold position than equal analog servo's. And forgot to mention that high framerate systems can only work with digital servo's.
For a few years I am running Savox SC-1257TG servo's on my Mugen MRX4X, the [email protected] and 10kg force are enough. Before that I had KO wit 0.08sec and 8kg, both good servo's, if they work for 1/8 then the will do for sure 1/10.
Cheap high torque servo's are most of the times slow, that can give problems with taking corners. A populair servo amoung starters is the MG995 servo, stay away from it. Although it seems to be a good servo regarding the specs it is not precise and can have some difficulties finding position what will give a strange feeling to drive with.
A good steering servo for 1/10th on road Bxclip Radio and Electronics 9 10-15-2010 07:52 AM
Preferred Servos for 1/10th on-road? js058515 Electric On-Road 6 08-01-2010 01:57 PM
best servos for 1/10th nitro on road tman45 Nitro On-Road 15 07-04-2010 10:45 AM
1/10th On-Road Sedan Shopping List for the Serious Racer rmdhawaii Chat Lounge 21 01-08-2010 11:27 AM
