Old 01-02-2013, 12:45 PM   #1
Default Nitro RC stalls when put it on the floor
Can someone please assist?
When I put my Nitro RC car on the floor it stalls
And the left and right wheels turns the opposite directions don't know if this is normal
Tuning seems fine not getting to hot and 1mm open.
Jaja is offline   Reply With Quote
Old 01-02-2013, 12:52 PM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
When turning one wheel it is normal that the other side going the other way, the differential is causing that.
When putting it on the ground the wheels are spinning?
If so then it is your clutch, check the springs, the shoes and bearings.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-02-2013, 01:02 PM   #3
What motor are you using?
jerzey10 is offline   Reply With Quote
Old 01-02-2013, 01:39 PM   #4
blis's Avatar
+1
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 01-03-2013, 12:53 AM   #5
Hi thanks but when I put it on the ground it immediately cutoff no time for it to test if it spins.
Old 01-03-2013, 12:59 AM   #6
bmain57's Avatar
The stalling can be a lot of things....to rich of a setting on the motor,clutch shoes burned and not grabbing the bell.
THANKS TO ALL MY SPONSORS...
MUGEN SIEKI USA, NOVAROSSI, KO PROPO AMERICA, PROTOFORM, AVID, FLASHPOINT FUEL AND TIRES.
bmain57 is offline   Reply With Quote
Old 01-03-2013, 01:00 AM   #7
idle up!
OrAnGe PoWeR is offline   Reply With Quote
Old 01-03-2013, 01:02 AM   #8
All I can see on the motor is G18 and the model of the car is HL Sprint
Old 01-03-2013, 01:10 AM   #9
blis's Avatar
Roelof already answered it... There should be no reason other than CLUTCH as to why the car will stop when placed on the ground. This means that your wheels MUST be spinning when you start it. The clutch will be partially or fully engaged and you need to readjust the gap or springs to free it up. It may be bearings seized or similar. Take a picture of the Engine and the Clutch and we nay be able to point out some details but this has nothing to do with tuning.
Old 01-03-2013, 01:21 AM   #10
Originally Posted by blis View Post
+1
You can click on my name and have a look for some reason the picture link does not accept the pictures URL
Old 01-03-2013, 02:19 AM   #11
If I push the car forward is it suppose to go forward or not move at all?
Old 01-03-2013, 04:16 AM   #12
blis's Avatar
You arent helping your own cause. But we are helpful and patient, to a point! Also, best take these questions to the Rookie Thread!
With engine stalled, and clutch locked/seized/stuck open/engaged. NO the car will not move unless it turns over the engine.
Remove the engine, remove the clutch and inspect! The clutch needs to spin freely in order for the car to idle.
You could just ignore everything we are saying and throw the car in a forward motion and not stop, but this will eventually damage the engine and car as you will be engine braking as well, not good for internals and transmission.
Old 01-03-2013, 05:36 AM   #13
Roelof's Avatar
Can you explain to me why this is important to know for a common issue?
A good answer is only possible with the right information with your question. As you have never aswered the question if the wheels are spinning of the ground at idle now you are not telling what your car does:
In all the time you are asking a lot you could have checked the clutch, really, it is a common thing it breakes down.....
Old 01-03-2013, 06:37 AM   #14
A good answer is only possible with the right information with your question. As you have never aswered the question if the wheels are spinning of the ground at idle now you are not telling what your car does: Yes it does spin of the ground
I did check the clutch and loosened it that is why I asked is the wheels suppose to move when I push the car forward while it is completely switched off before it could not move now it can.
Old 01-03-2013, 06:41 AM   #15
Where is the rookie Thread?! This site is to confusing.
Who says I am ignoring everything
