Old 04-13-2005, 02:36 PM   #1
dct147's Avatar
Default Glow Plug and Engine
Hi Guys,
Have 2 probelms here.
1) recently lost my washer that comes with my glow plug, and ever since, fuel`s been splashing out from my cooler head. Is it due to the washer? is there a way i can prevent it (i have tightened it fully with all my strength)? Also, will it be harmful to my engine if i continue to run without the washer? or should u just get a new one? it`s a stock washer that comes with my FW05T.
2) after a couple of crashes on my car today, nothing went wrong , rather, my car performed better than usual. after stopping due to the flooding of fuel on my car, i realized my air filter came out. Was running on a VERY DUSTY track without it all along. I know it`s very bad for my engine, how can i clear all the unwanted dirt in my engine? i have injected fuel in from my carb and flushed it. is that good enough? or is there anything better that i can do?
Thanks for your help guys.
Cheers!!
dct147 is offline   Reply With Quote
Old 04-13-2005, 03:13 PM   #2
dct147,
Start by going an get a new glow plug. Running without the washer causes a overlean condition due to air leak. I hope you didn't strip the threads when you tightened the plug with all your strength.
Without having to disasemble the entire engine to clean out the dust, just richen the motor till it 4 strokes and blip the throttle a bunch of times. Then retune for race conditions.
Jamie Corrado is offline   Reply With Quote
Old 04-13-2005, 10:38 PM   #3
dct147's Avatar
Thanks alot Jamie Corrado,
I understand about the washer.
but i don`t understand what u mean by just richen the motor till it 4 strokes and blip the throttle a bunch of times?
Do u mean i richen my mixture and run it?
Thanks for your help once again.
Old 04-14-2005, 12:52 PM   #4
dct147's Avatar
Are there any other methods? i haven`t done it. still don`t know what to do.
My car will be out of action cause i`m afraid of hurting the engine.
Thanks guys!
Old 04-16-2005, 07:33 PM   #5
DCT147,
Richen your motor until it barely stays running and is spitting out alot of oil from the pipe. Then just blip the throttle afew times to flush it out. Re-tune the engine and you should be all good. Don't worry, you probably did no harm to the engine, just do this as a precautionary measure.
Old 04-16-2005, 10:22 PM   #6
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default engine cleaning
hey if you don't know what to do, have someone help you. take the backplate off the motor if you have a pull starter first remove it make sure your glow plug and air cleaner are off. and then thoroughly use a spray cleaner or fuel and pour it in the carb and the glow plug hole and in the crankcase area to ensure no dirt or debris scores your piston and sleeve. don't take chances unless you got lots of money always be safer than sorry
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 04-17-2005, 12:59 AM   #7
dct147's Avatar
got it guys,
Thanks alot.
How does glow plug temps affect an engine? Cain Nitro Off-Road 11 07-29-2007 10:01 AM
Glow plug for STS engine Dpepin Onroad Nitro Engine Zone 2 06-19-2007 06:56 PM
engine and or glow plug problems adelaidean Electric Off-Road 5 03-14-2007 10:47 PM
Engine won't Rev Up and Glow Plug Trouble tarheel23 Nitro On-Road 5 07-25-2006 08:26 PM
Glow Plug For Rb Engine SERPENTFREAK69 Onroad Nitro Engine Zone 4 07-27-2004 09:36 PM
