Old 04-11-2005, 04:42 PM   #1
factory racer's Avatar
Default ntc3 BRAKE PAD PROBLEM
i have an NTC3 and some fuel or oil got on the brake pads......is it normal for them to harden up and not work at all......even if i apply excessive force on the brake pads with the brake disc, it still doesnt work.......please give me some feedback
thanks!!!b
factory racer is offline   Reply With Quote
Old 04-11-2005, 07:19 PM   #2
nitrodude's Avatar
I would take the disk and the pads off the car and wipe everything clean. Make sure that the pads are there, as they could have come off. If the pads are on and everything is clean, you can sand the disk and the pads with some 220 sand paper. Sometimes the disk and/or the pads get glazed, that could be your problem.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-11-2005, 07:30 PM   #3
subman's Avatar
sounds like they are glazed. Rough them up with some sandpaper!
subman is offline   Reply With Quote
Old 04-12-2005, 06:20 PM   #4
ok thanks alot guys, one question. does it have to be 220 sand paper or can it be any like is it thick or thing grain sand paper????
thanks
Old 04-12-2005, 07:28 PM   #5
nitrodude's Avatar
Any will do, but I woulnt go finer than 220, if you do, you might make it worst. You need to scratch it a little, not just to clean it, but also so the pads have something to grab onto.
Steven Muller
Ronin Speed Parts
Old 04-13-2005, 12:44 PM   #6
Send a message via ICQ to Grasshopperr Send a message via AIM to Grasshopperr Send a message via Yahoo to Grasshopperr
just to be safe I would replace the disc an pads
Grasshopperr is offline   Reply With Quote
Old 04-13-2005, 08:28 PM   #7
AndyT 's Avatar
While you have the brake disc out of the car, give it a good clean with either some isopropyl alcohol or denatured alcohol......you`ll be surprised at how much rubbish ends up on the brake disc.
Cheers
AndyT  is offline   Reply With Quote
Old 04-14-2005, 02:22 PM   #8
is 280 sand paper fine???????
Old 04-14-2005, 07:28 PM   #9
soc123_au's Avatar
R/C Tech Charter Subscriber
The higher the number the finer the paper.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 04-16-2005, 05:30 PM   #10
i no that but should i use finer paper or rougher paper to sand down the pads???????b
Jato brake problem Motoman Nitro Off-Road 2 07-14-2008 10:09 PM
hyper 7 brake linkage problem derricklong38 Electric Off-Road 1 02-14-2007 08:11 PM
LRP Speed Comp, 3PK, Spektrum Pro - Drag Brake Problem or8ital Electric On-Road 2 02-06-2007 07:03 AM
fw-05r - brake linkage problem ?? mrgsr Nitro On-Road 5 02-27-2005 03:03 PM
NTC3 brake pads froghead R/C Items: Wanted to Buy 0 04-14-2004 11:58 AM
