Old 01-27-2013, 08:55 PM   #16
Default My ride...
Originally Posted by Racer-rich View Post
Here is a photo of my kf01. I hope that I can get the link correct
-Rich
I love the details on your rig. I gotta get me that graphite chassis and stiffener
Current Livery
Latest upgrade, Tuned pipe
1. tuned pipe
2. Lightened flywheel and clutch (R246 Upgrade house) noticeble increase in throttle respones
3. Upgraded brake disc
4. rear and middle bulkheads made of aluminum, parts from Spada 09
5. R246 Cooling head, with this increased air flow as well as being able to use conventional glow plugs
My First Livery
Heads up
1. Longer fuel tubing adds a lap or two to run time depending on track
2. Check out camber adjust spacers (no need of cliper measure)
3. Tamiya trun buckles (any will do in place of stock ones)
4. Aluminum steering pin and knucles increase durability
5. Exceed RC, F103 foams hard front and soft rear
6. Ride height spacer, I'm running a 2.0mm drop (1.5+0.5mm)
momoyluds is offline   Reply With Quote
Old 01-27-2013, 11:50 PM   #17
Default rx enclosure...
-Rich
Hi Rich,
Where did you get the rx enclosure?
Marty
Old 01-28-2013, 12:24 PM   #18
Originally Posted by momoyluds View Post
Hi Rich,
Marty
Hi Marty,
That is a standard Kyosho nitro receiver cover that I got many years ago for my other nitro cars. The receiver covers came in several different colors. Unfortunately I do not remember what the part number is.
Sorry,
-Rich
Last edited by Racer-rich; 01-28-2013 at 12:44 PM. Reason: Uploaded receiver cover image
Racer-rich is offline   Reply With Quote
Old 01-28-2013, 12:36 PM   #19
Current Livery
1. tuned pipe
My First Livery
Heads up
Man that is one sweet ride!
My thinking on the stiffener was that it will help prevent the bottom chassis from bending in a really hard crash and not so much for handling reasons.
If you want some decals for you McLaren body I got mine from F1paintlab
http://f1paintlab.mybigcommerce.com/...-6-full-sheet/
I noticed that there is a fair amount of droop in the rear axle, did you adjust the droop if so how?
-Rich
Old 01-28-2013, 06:24 PM   #20
Default Droop
-Rich
Hi Rich,
I used R246 ride height spacers. They mount between the chassis and the bulkhead, both on the front and rear. We have a treated surface we run on and with foams, I needed to lower the center of gravity of the car, it corners on rails
In your case, running out side, you may need to run a tad higher, lest the track is purpose built, then drop your kit when using foams. With rubber, I need to increase ride height and softer springs out rear, I'd say med to even soft for more rear end grip. it should give you a good baseline, but I'd suggest doing some on track testin with a stop watch, and see which setup works for you
-marty
Old 01-28-2013, 07:23 PM   #21
NutDriver's Avatar
Trader Rating: 19 (100%+)
These posts are REALLY tempting me to contact Banzai Hobbies!!
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 01-28-2013, 07:26 PM   #22
Default Droop
Hi Rich,
-marty
Hi Marty,
Thanks, sorry but i think that i did not ask the question well enough, as I think that you are talking about ride height and not what i call droop. Let me try asking the question differently.
When you raise the rear of the car from rest there is a small difference in ride height between when the springs are still engaged and pressing against the axle and when the rear tires actually leave the ground as you continue to raise the rear of the car. This difference in ride height between when the spring stop pushing against the axle and when the tires actually lift is what I would call droop. I see about 4mm of droop on my car and about 6mm normal ride height in the rear (I am using 2mm of spacers in the rear).
How much droop are you seeing if any on you car?
Does the metal rear bulkheads you have got an adjustment screw to limit how far the axle can move downward? That would be the droop adjuster.
-Rich
Old 01-30-2013, 01:17 AM   #23
Default droop
Hi Marty,
-Rich
Hi Rich,
If there is any droop, it was unintentional. I simply ordered the rear bulkheads of Spada 09, I assumed they were the same dimensions and opted to use them. I don't recall seeing an adjustment screw, but I think some further scruteneering is in order
marty
Old 01-30-2013, 03:55 AM   #24
I am trying to confirm what the SP kit comes with. I comes with the different chassis and top plate and ball diff, does it come with the two speed?
fritzzz is offline   Reply With Quote
Old 01-30-2013, 11:53 AM   #25
Default SP kit
Hi,
The SP version does not include a two speed or the tuned pipe. The listed options included are:
-carbon main chassis and 7075 alum engine plate.
-carbon top chassis.
-ball diff.
-stainless steel front king pins.
-kit is packaged without body so you can choose your preferred formula body from the three available.
Here is the Kyosho website for the kit:
http://www.kyosho.com/eng/products/r...duct_id=107675
I hope that this answers your questions,
-Rich
Old 01-30-2013, 12:04 PM   #26
Default Droop
Hi Rich,
marty
Ok, thanks for looking.
The reason I was asking is that adjusting the droop can help with the weight transfer under braking i.e. help with the oversteer entering into a corner.
-Rich
Old 01-30-2013, 04:55 PM   #27
Hi,
-ball diff.
-Rich
Thanks Rich, the main thing I was unsure about was the two speed as one of the posts in here mentioned the two speed was in the SP kit. Mine will be a shelf queen so I'll go with the basic kit and buy the ball diff and two speed rather than buying the SP kit, two speed and a body.
Old 01-30-2013, 07:07 PM   #28
NutDriver's Avatar
How much are the tuned pipe and the two speed?
USVTA member #111
Old 01-30-2013, 08:05 PM   #29
Hi,
Current prices at bonzai hobby:
Kfw025- two speed transmission set for kf01 =>$33.38
Kfw019- tuned pipe for kf01 => $50.95
Link to bonzai hobby:
http://banzaihobby.com/index.php?mai...pto=&x=35&y=12
-Rich
Last edited by Racer-rich; 01-30-2013 at 08:10 PM. Reason: Add link to bonzai hobby
Old 02-13-2013, 02:02 AM   #30
Default Exceed tires
Current Livery
1. tuned pipe
My First Livery
[URL=http://imageshack.us/photo/my-images/13/broadsiden.jpg/]
Heads up
Hi Marty,
Where do you get your exceed RC tires from?
Thanks,
-Rich
Tags
f1-1/10 nitro, kyosho kf01
