Serpent 977 Viper >
Serpent 977 Viper
Like Tree14Likes
Serpent 977 Viper
Old 06-20-2016, 04:04 AM
  #1066
JamesHealey's Avatar
My 977 Evo came with the new split mount for the Otto engines, but I run Novarossi engines anyway, so wasn't needed.
JamesHealey is offline
Old 06-20-2016, 09:03 PM
  #1067
I bought the 35th aniv 977 and by the second/third bag I am having extra parts. I got the manual online and did everything right. Also is the thumb drive that comes with it supposed to have something on it or is it supposed to be an empty 1.85gb drive? I am asking because there is nothing on mine, but the bag it was in says manual, but no such thing was on it.
R10 Rob is offline
Old 06-20-2016, 09:30 PM
  #1068
hvychevy94's Avatar
thanks for the info..I emailed them and they said check back in a couple of weeks
hvychevy94 is offline
Old 06-20-2016, 09:31 PM
  #1069
hvychevy94's Avatar
how about sending it over here!! I sure could use it
Old 06-21-2016, 05:15 AM
  #1070
dan_vector's Avatar
Trader Rating: 27 (100%+)
Yeah Serpent do add a few extra bits and pieces in the kits. The anniversary edition has some extras included as well. The website says that it has the chassis stiffener, carbon aero discs, flex-set, brass chassis weight, alu servo saver, carbon transponder holder, alu wheel axles, and CVD's as standard which are all options over the standard evo car.
The thumb drive is supposed to have the manual, setups, serpent history and catalogs. If yours is blank perhaps an email to them would be a good idea so they could email you the missing files.
dan_vector is offline
Old 06-21-2016, 09:05 AM
  #1071
I know about the extra parts, but those are in separate bags. I mean in the regular bags I have a left over screw in one, and two cylindrical pieces with set screws left over and no place for them.
R10 Rob is offline
Old 06-21-2016, 10:14 AM
  #1072
dan_vector's Avatar
Don't worry about it. You'll have some spare screws left over during the build. Better to have a surplus than not enough
Post a photo of the cylindrical pieces you mentioned. I'm not sure but these.
Old 06-21-2016, 01:46 PM
  #1073
I figured out what I missed. Directions do not seem to be as good as the 748. Kind of surprised the rear diff is locked on the 977. I emailed them about the flash drive, but just got the manual, not the setup sheets or the history...
R10 Rob is offline
Old 06-21-2016, 02:07 PM
  #1074
dan_vector's Avatar
No 1/8 track car has a rear diff. All are fixed rear axle and one way fixed front axle. That is the class standard!
Old 06-21-2016, 04:56 PM
  #1075
Can someone with the 35th flash drive copy and send me all the files? Serpent only gave me the manual.
R10 Rob is offline
Old 06-22-2016, 05:43 PM
  #1076
hvychevy94's Avatar
The centax nut on the clutch system, how do I tighten it without over tighten. Is it ok to use pliers?
Old 06-22-2016, 07:20 PM
  #1077
The nut for the flywheel or the one for the spring?
nitrodude is offline
Old 06-22-2016, 07:50 PM
  #1078
hvychevy94's Avatar
Old 06-22-2016, 09:08 PM
  #1079
It's OK to use pliers, but it will be easier to adjust if you get the proper tool
Old 06-23-2016, 04:51 AM
  #1080
hvychevy94's Avatar
What I see there is this tool http://www.serpent.com/product/1462/ but I can't find it no where..what other tool can I use?
