Old 12-16-2012, 07:37 PM   #1
Default Help identifying an HPI
Hi guys. Just bought a used HPI, what I thought was an RS4 3. Messed with it today and it's having issues pressurizing the fuel tank, found the tank has a leak. I went through everything I could find on HPI's site and I can't find a model with this style tank and mount. Can anyone help me to identify what I have so I can order a new tank? TIA
Site won't allow me to post links so I can't post up pictures. The tank has both the outlet and inlet on the top of the tank, that seems to be the difference between it and the others I see in their pics.
brodee is offline   Reply With Quote
Old 12-16-2012, 07:48 PM   #2
hotrod87's Avatar
Trader Rating: 252 (100%+)
Location of the tank differs on some of them also. Really need pics.
Did you look at their website where they have the non current models?
ON A WALKABOUT AS OF 7/27/17
hotrod87 is offline   Reply With Quote
Old 12-16-2012, 07:54 PM   #3
I can email pics, site won't let me link to them, not enough posts yet
Old 12-16-2012, 07:56 PM   #4
There we go, now it's letting me. Tank placement and everything is the same as the RS4-3 but the way the tank mounts and the tank itself is different. The tank is leaking around the lid so worst case I guess I could get a new lid.
Old 12-16-2012, 08:01 PM   #5
There are 2 tanks that will work. Stock #87021 has a built in primer or you could use stock #72525 that does not have the primer, this is the racing tank.
If you search the HPI site with these stock #s you will see pictures of each tank.
I would recommend 72525.
X
I just saw ur picture, never seen that tank mounting configuration. I have not run a HPI in a long time but still have my RS4-3 SS and it can use either of the tanks I mentioned above.
Are you sure that is a HPI car?
X-Factor is offline   Reply With Quote
Old 12-16-2012, 08:07 PM   #6
I have one of those tanks from my RS4-2. The problem is the rear mount won't fit on this car unless I'm missing something. If you look at that second picture this tank mounts offset on the rear, the other tanks like the 87021 mount in the center front and rear. Am I missing something?
Old 12-16-2012, 08:28 PM   #7
Well there you go, it's not an HPI, it's a Himoto. Now I have to figure out which one. And go talk to the shop that sold it to me as an RS4
Thanks for all the help, much appreciated.
Help Me Identify This Car! Klen420 Electric On-Road 26 09-21-2016 04:17 PM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
