Old 08-30-2002, 03:13 AM   #121
SmeltzRacing is offline   Reply With Quote
Old 08-30-2002, 08:01 AM   #122
Originally posted by mobil1rac
muugen can you tell me where the picture that you have with your name, where did the sleeve come from. I am very courious about it. thanks
Mobil1rac....email if you need info on the sleeve and the Jtech motor
leefjl is offline   Reply With Quote
Old 08-30-2002, 09:15 AM   #123
InitialD's Avatar
Smeltz, the mods look cool
Have you tested it out yet? What's the performance like?
How's the quality out of the box?
Old 08-30-2002, 09:16 AM   #124
InitialD's Avatar
Hi there leefl, I received your copy email to Jason Bell. However still no response despite contacting him personally... Busy perhaps?
Old 08-30-2002, 02:50 PM   #125
Old 08-30-2002, 05:31 PM   #126
glitch44's Avatar
Matt,
The pix look great! I can't wait to break the beast in. I'll see you tonight.
glitch44 is offline   Reply With Quote
Old 09-03-2002, 07:54 PM   #127
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Default price
Originally posted by SmeltzRacing
I will keep you posted on the test results of the Sirio. The quality of this motor is right up there with the Rossi Pixie Black.
Hi SmeltzRacing
How much you sell the Rossi Pixi black??
tl2111 is offline   Reply With Quote
Old 09-09-2002, 05:37 PM   #128
glitch44's Avatar
Matt,
Thanks for all your support this weekend. The SMELTZ Sirio 12 has to be my fastest motor to date. The performance so far, has exceeded all of my expectations and with only half a gallon thru her. I can't wait to put the other carb and button on. Again, thanks and I'll see you Friday night.
Old 09-13-2002, 08:51 AM   #129
patelladragger's Avatar
Send a message via AIM to patelladragger
So what's the scoop - the sirio looking stronger than the pixie?
patelladragger is offline   Reply With Quote
Old 09-16-2002, 08:11 AM   #130
2Fast4U2's Avatar
I also got my Engine(MT12) from Matt last week, ran it this weekend. Real strong low end and mid range. I could see the power difference. Had plenty of run time, it could of went 7 min with it as well. My car had never gone as fast as it did. Very impressed with the performance. I like it!!! Can't wait to see its top end on a big track.
Thanks for the excellent Turn-around time. That in it self is what impressed me as well.
Tim
2Fast4U2 is offline   Reply With Quote
Old 10-11-2002, 04:27 PM   #131
Talking
Old 10-12-2002, 06:14 AM   #132
VenomWorldOrder's Avatar
how do you achieve the smoothness on the inside of the car intake? what do you use?
on a old engine that i'm fooling around with i couldn't find a buffing tool small enough to reach the lower section of the carb. so i left it roughish. also do you use a stone bit to make the carb intake larger? (not the actual intake hole but the internal carb body section).
what head shims do you use on your modified engines? just the stock aluminium ones or do you add a copper shim also? if so have you found that the engine revs higher with a extra copper shim?
why is everyone polishing the carbs now? i initially read that the rough carb intake helps with the air fuel process. ( maybe this theory is in line with the opinions posted on the previous pages)
VenomWorldOrder is offline   Reply With Quote
Old 10-13-2002, 10:36 AM   #133
asd
Send a message via ICQ to asd
hello, i'd like someone to answer my ques, her it goes:
what modification is most effective in an engnies performance?
ie., porting, polishing and on what parts?
asd is offline   Reply With Quote
Old 10-14-2002, 04:56 PM   #134
You will never notice the difference between a polished motor and a rough motor. There are some things that need to be left rough to help with the atomization (sp) process. The only gains that you will find is with changing port timing, just like putting in a more radical cam in a real car. Your trying to maximise all the air/fuel that you can. It is a balancing act, if you advance the intake you must advance the exhaust or else you will have for a very inefficient motor. The rest you'll have to figure out on your own...
JPHRacer is offline   Reply With Quote
Old 10-23-2002, 03:06 PM   #135
Trader Rating: 2 (75%+)
Thumbs up
WWOOOO HHHOOOOO.........OUTSTANDING WORK SMELTZ!!!!
I have a Sirio coming to me soon.......how much to send it to you for modified Sirio!?!?!
PUNISHER is offline   Reply With Quote
Modified motors Phroz Australian Racing 4 01-14-2007 08:26 PM
Brand New Smeltz Modified Rossi .12 Pixy Black Nitro Engine racer rich R/C Items: For Sale/Trade 5 02-21-2005 11:10 AM
Modified Motors 35.00 TSB R/C Items: For Sale/Trade 1 07-25-2004 12:16 AM
Smeltz modified Mt-12 CraigH R/C Items: For Sale/Trade 2 10-26-2003 04:59 PM
Smeltz modified Mt-12 CraigH R/C Items: For Sale/Trade 1 08-02-2003 07:05 AM
