Old 04-02-2005, 03:42 PM   #1
dct147's Avatar
Default Shaft gearing chipped and worn teeth
Hi all,
Just took my car for a spin ( at a very bad location) in a carpark full of pebbles and stones.
Now, my car is not ever 2 weeks old, the teeth on my shaft are chipped and worn down. was wondering, under what circumstances ony will u guys change them? is it necessary to change them now? tried to take pics of it to show u guys, but doesn`t come out clear.
Help pls..
Thanks!
Cheers!!
dct147 is offline   Reply With Quote
Old 04-02-2005, 05:56 PM   #2
AndyT 's Avatar
If the drivetrain is starting to bind and not turning over freely, thats when i`d be looking at replacing gears.
AndyT  is offline   Reply With Quote
Old 04-02-2005, 08:27 PM   #3
rcabj's Avatar
hi..its better not to run your car on dirty surfaces....
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 04-02-2005, 08:58 PM   #4
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default chips in gears
if you have one or two chips at different places around your gear it should be ok, but if two or three in a row are wore down it would be better to change the plastic ones so the alluminum ones aren't affected. plastic is cheaper always make sure you keep the gears as close as possible while still spinning them freely (no binding)
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 04-03-2005, 06:11 AM   #5
dct147's Avatar
Thanks all for your help.
The teeth are all worn down cause of previous run. Gears were too loosely positioned thus, the aluminum ones kinda flattened all the plastic ones already ( still able to run. just a little flattened). shoot me!!!!!
Now, I would say 70% of the plastic teeth has holes in them in the middle and some at the side. The chipped ones, about 2 or 3 all in different places.
How does that sound? should i change yet?
also, 1 more question, when i reverse my car manually, the gears move together, should i hear any sound? cause i`m hearing alittle. have seem my friend`s move totally silently. I`m using a Kyosho FW05T.
Sorry AndyT. what`s a drivetrain?
Cheers!!
Old 04-03-2005, 09:29 AM   #6
your drivetrain is basically all the shafts and gears and cluth that make a car go. sometimes you have a bad bearing or your pulley is press against it to tight. and also sometimes your brakes might bind. so when your car does not roll freely you have to isolate the problem and fix it. Now yours is definetely the gears. So if you are just bashing around the parking lot and your gears are shot already but your car still goes then keep using them. If you plan on racing you always want those gears to be in good condition.
Old 04-03-2005, 11:41 AM   #7
dct147's Avatar
That really helped my problem.
Thanks alot.
I`m just bashing around for now, but i will be racing once i`m primed and getting my pockets more filled up.
Thanks all u guys!!
Cheers!
Old 04-03-2005, 03:15 PM   #8
your welcome, remember to save a little extra for spare parts and always do a quick check over of all the screws and nuts before each race. sometimes you will save some cash by talking a little extra time to check out the car. good luck Peter
Old 04-03-2005, 05:05 PM   #9
AndyT 's Avatar
Originally posted by Speedypeterb
, remember to save a little extra for spare parts Peter
Once you start racing its very handy to have a couple of spare spur gears (the plastic ones) and some pinion gears (the aluminium ones on the clutch bell) in your tool box.....these are quite vulnerable to getting damaged by pebbles etc.
Cheers
Old 04-03-2005, 10:35 PM   #10
dct147's Avatar
Noted.
Thanks again Guys!
Cheers!!
Old 04-05-2005, 10:34 AM   #11
dct147's Avatar
Hi guys, another slight problem i`ve encountered.
As i`m running the FW05T, when i manually reverse the car, the gears rub each other, move and make some noise.
Today i saw a friend`s same model car, was silent when i moved it backwards (that`s probably cause his teeth arn`t worn out like mine). but when i manually moved the car forward, the gears actually moved too. My gears only move when i move backwards doesn`t move when i push it forward. I`ve tried to tighten it, loosen it, same effect. if there anything wrong with my car?
Thanks for your help once again.
Cheers!
Do I Brush My Teeth To Much ? xsxracing Chat Lounge 17 01-03-2008 05:55 AM
For Sale - Chipped Xbox! + LOADS MORE. Mloclamau Australia For Sale/Trade 11 06-05-2007 02:54 AM
Need help with my shaft / gearing dct147 Nitro On-Road 8 03-29-2005 12:46 PM
sharpening chipped Diamond lathe bits Super Steve Electric On-Road 10 05-30-2004 11:00 PM
How to tell when diamond bit is chipped? Addict sa RC Electric On-Road 12 05-15-2002 08:29 PM
